Hi Flo1991,
I'm running the steps on https://communities.intel.com/message/397345# 397345 https://communities.intel.com/message/397345# 397345 to check if I get the same outcome. I do not have Lubuntu, I am currently using Ubuntu 14.04. As you may know the Supported Linux Distributions are listed in: http://www.yoctoproject.org/docs/1.7.3/ref-manual/ref-manual.html# detailed-supported-distros so I highly suggest using one of those. I'm running the bitbake right now, in which step did you obtained the error you posted? Let me know so I could try to replicate it.
Did you install all the dependencies recommended in the BSP? http://www.intel.com/content/dam/support/us/en/documents/edison/sb/edisonbsp_ug_331188007.pdf
Charlie
The error happens at around task 2308 when running bitbake edison-image u-boot.
All dependencies should be installed (apt-get install build-essential git diffstat gawk chrpath texinfo libtool gcc-multilib)
or did I miss anything?
Flo1991
Hi Flo1991,
Yes, those are the ones you need. Have you tried by installing OpenJDK in your PC?
I think the problem is that we are missing a dependency. Try installing OpenJDK and icedtea7 in your PC.
You can also try to disable icedtea7 in your build and use only icedtea6.
Let me know the outcome of trying this; remember to clean the build after every try or to start from scratch every time.
http://icedtea.classpath.org/wiki/Main_Page http://icedtea.classpath.org/wiki/Main_Page
http://www.linuxfromscratch.org/blfs/view/7.9/xsoft/icedtea-web.html http://www.linuxfromscratch.org/blfs/view/7.9/xsoft/icedtea-web.html
http://icedtea.wildebeest.org/download/source/ http://icedtea.wildebeest.org/download/source/
Charlie
Thank you I will try this the next days.
How can I clean the build? Is there a specific command for bitbake?
Flo1991
Hi Flo1991,
Sounds good, let me know any update.
For cleaning the image you can try with "bitbake -c cleanall -f ", "bitbake -c clean TARGET", "do_clean flag", "bitbake virtual/kernel -c clean"...
Look at these links:
/message/394214# 394214 https://communities.intel.com/message/394214# 394214
https://community.nxp.com/thread/353311 YOCTO project clean | NXP Community
http://wiki.kaeilos.com/index.php/Bitbake_options Bitbake options - Wiki Kaeilos.com
Or you could remove the build folder.
Charlie
After installing OpenJDK and icedtea7 the build went fine :-)
Thank you for your help.
Flo1991
