I have read many thread about how build an image of intel edison, but I have always errors. Why we can't compile WHITOUT errors sources download directly from intel web page ?
I have read the BSP doc...
Page 7 on https://www.intel.com/content/dam/support/us/en/documents/edison/sb/edisonbsp_ug_331188007.pdf# page7 intel edison board support package
I have install all prerequisite package
source poky/oe-init-build-env => OK
bitbake edison-image => NOT OK
several error like this thread:
I have tried to replace the "poky/meta-java/recipes-core/icedtea" folder due to error of checksum but it doesn't work
I have an other problem with openjdk-8-jre
Where i can find a source package which compile or some step to have a buildable project ?
Thanks for reply.
My Promt say:
ERROR: Fetcher failure for URL: ' http://icedtea.classpath.org/hg/release/icedtea7-forest-2.1/archive/f89009ada191.tar.bz2;name=openjd...'. Checksum mismatch!
File: '/home/franck/Bureau/edison-20160606/build_edison/downloads/f89009ada191.tar.bz2' has md5 checksum 2bc941373ca4b033c9a25f972eec7858 when c26bbb33addfaeb14d28a1329b4b5a3e was expected
File: '/home/franck/Bureau/edison-20160606/build_edison/downloads/f89009ada191.tar.bz2' has sha256 checksum 5efd8e66f18fcbf45527bcc74aa3e6ed11f66bc793c88e3841925c4acb4827ba when 54a0ef02b56b265b4122324e08a33c42ececbf2a300ada260611e7b6ccdba96d was expected
If this change is expected (e.g. you have upgraded to a new version without updating the checksums) then you can use these lines within the recipe:
SRC_URI[openjdk.md5sum] = "2bc941373ca4b033c9a25f972eec7858"
SRC_URI[openjdk.sha256sum] = "5efd8e66f18fcbf45527bcc74aa3e6ed11f66bc793c88e3841925c4acb4827ba"
Otherwise you should retry the download and/or check with upstream to determine if the file has become corrupted or otherwise unexpectedly modified.
ERROR: Function failed: Fetcher failure for URL: ' http://icedtea.classpath.org/hg/release/icedtea7-forest-2.1/archive/f89009ada191.tar.bz2;name=openjd...'. Unable to fetch URL from any source.
ERROR: Logfile of failure stored in: /home/franck/Bureau/edison-20160606/build_edison/tmp/work/x86_64-linux/icedtea7-native/2.1.3-r1.0/temp/log.do_fetch.13837
ERROR: Task 2976 (/home/franck/Bureau/edison-20160606/build_edison/../poky/meta-java/recipes-core/icedtea/icedtea7-native_2.1.3.bb, do_fetch) failed with exit code '1'
NOTE: Tasks Summary: Attempted 1479 tasks of which 1390 didn't need to be rerun and 1 failed.
Hi Francknos,
Thank you for contacting us.
First, we want to apologize for the problems that this might be causing you, and I will try my best to help you.
Yes, you are right you can't build the image using the sources that are downloaded, and it is because the repositories are constantly changing. I was able to build image with the following steps, consider that I built it using Ubuntu 14.04 (kernel version 4.4.0-38-generic):
1. Make sure that you have Git 1.7.8 or greater, tar 1.24 or greater, Python 2.7.3 or greater excluding Python 3.x, which is not supported.
2. Install all the dependencies with the command:
sudo apt-get install gawk wget git-core diffstat unzip texinfo gcc-multilib \ build-essential chrpath socat libsdl1.2-dev xterm
3. Download and unzip iot-devkit-yp-poky-edison-20160606.zip ( http://iotdk.intel.com/src/3.5/edison/iot-devkit-yp-poky-edison-20160606.zip).
4. Go to iot-devkit-yp-poky-edison-20160606/poky/meta-intel-edison/meta-intel-edison-distro/recipes-core/images/edison-image.bb and comment or delete the following lines:
IMAGE_INSTALL += "iotkit-comm-js" IMAGE_INSTALL += "iotkit-comm-c-dev"
5. Go to http://git.yoctoproject.org/cgit/cgit.cgi/meta-java/commit/recipes-core/icedtea/openjdk-7-03b147/sig..., download the patch and unzip it.
7. Go to iot-devkit-yp-poky-edison-20160606/poky/meta-java/recipes-core/ant and delete the file called ant-native_1.8.1.bb, replace it with the file with the same name found in /meta-java-master/recipes-core/ant/.
8. Go to iot-devkit-yp-poky-edison-20160606/poky/meta-java/recipes-core/icedtea/ and delete the file called icedtea7-native_2.1.3.bb, replace it with the file with the same name found in /meta-java-master/recipes-core/icedtea/.
9. Go to iot-devkit-yp-poky-edison-20160606/poky/meta-java/recipes-core/icedtea/openjdk-7-03b147/ and delete the file fix-checksums.patch, replace it with the file with the same name found in /meta-java-master/recipes-core/icedtea/openjdk-7-03b147/.
10. Go to iot-devkit-yp-poky-edison-20160606/poky/meta-intel-iot-devkit/recipes-connectivity/bacnet-stack and open the file called bacnet-stack_0.8.2.bb. Look for the line:
SRC_URI = " http://sourceforge.net/projects/bacnet/files/bacnet-stack/bacnet-stack-${PV}/bacnet-stack-${PV}.tgz \
And change it for:
SRC_URI = " https://svwh.dl.sourceforge.net/project/bacnet/bacnet-stack/bacnet-stack-0.8.2/bacnet-stack-0.8.2.tg... \
11. Then follow the usual steps:
cd iot-devkit-yp-poky-edison-20160606/poky/ source oe-init-build-env ../build_edison/ bitbake edison-image u-boot ../poky/meta-intel-edison/utils/flash/postBuild.sh . zip -r toFlash.zip toFlash
I hope you find this useful, and let us know if it works for you.
Have a nice day.
Leonardo R.
francknos This has been a frustration for many of us. In the official repo's related to Edison there seems not to much going on. Fortunately, it is all open source. Kernel development continues, U-boot development continues, Yocto development continues. So, I decided to fork meta-intel-edison + whatever else needed fixing. It is more or less based on the Edison 2.1 image.
You can find my new images here: https://github.com/htot/meta-intel-edison GitHub - htot/meta-intel-edison: Here is the meta-intel-edison that builds, tries to stay up to date and provides a PREE…
There are four branches that generate 4 different images:
- dizzy-uptodate tracks origin/dizzy with 3.10.98 kernel. This branch pulls https://github.com/htot/meta-intel-edison/blob/master/URL https://github.com/htot/meta-intel-iot-middleware.git branch dizzy-uptodate with fixes for paho-mqtt relocated and iotkit-comm-js no longer supported.
- dizzy-latest tracks origin/master as much as possible with 3.10.98 kernel. This branch pulls https://github.com/htot/meta-intel-edison/blob/master/URL https://github.com/htot/meta-intel-iot-middleware.git branch dizzy-latest with fixes for paho-mqtt relocated and iotkit-comm-js no longer supported + java support removed. This gives mraa 0.9.0, upm 0.4.1 and mosquitto 1.4.
- dizzy-rt same as dizzy-latest but with real time kernel. Switches the kernel to the PREEMPT_RT 3.10.17-rt kernel
- morty experimental branch based on Yocto Morty, vanilla kernel 4.11
If you select one of these branches on github, you will see the contents of the README.md change to the appropriate info for that branch. For morty build instructions can be found on the wiki pages.
To me the most exciting are dizzy-rt and morty. But, if you are just looking to build a new image and can't because the official 3.5 image needs manual modifications try out dizzy-uptodate or dizzy-latest. To get the dizzy* variants to the 3.5 state (and building), more layers need to be added. If somebody needs that done, please fork me and send a pull request with the changes needed.
Of course, adding layers to morty should be less painfull as these can be directly taken from the openembedded layers here: http://layers.openembedded.org/layerindex/branch/morty/layers/ http://layers.openembedded.org/layerindex/branch/morty/layers/
Help on morty work is highly appreciated, especially in testing and adding back features that I removed (current list of packages installed https://raw.githubusercontent.com/wiki/htot/meta-intel-edison/edison-image-edison.manifest https://raw.githubusercontent.com/wiki/htot/meta-intel-edison/edison-image-edison.manifest).
Also, I believe many would be happy to see mraa ported to the vanilla (currently 4.11) kernel, so their mraa based applications will work again. Noteworthy things that need to be changed: serial port moved from ttyMFD2 to linux standard ttyS2, pincontrol and pinmux changed to linux standard. The mraa abstraction that takes care is this and needs porting is : https://github.com/intel-iot-devkit/mraa/blob/master/src/x86/intel_edison_fab_c.c mraa/intel_edison_fab_c.c at master · intel-iot-devkit/mraa · GitHub
Ferry
Thanks for yours reply FerryT .
I'll try this tomorrow.
what is real time branch ?
I'll use edison to manage application will communicate in wifi to transfer throu wifi big image about 10 000 * 800 pixel in real time the construction of image is made by a coder an takes about 10 seconds to have width of 10 000.
My code works well on PC, I hope that edison will be strong to do this.
I use Qt framework to do that so I need to add meta-qt5 to image normally this meta complu without error.
What branch you suggest me to do that ?
Thanks again for your reply.
I have some trouble when I use make setup commande, impossible to clone 'poky-mirror.git'
franck@franck-VirtualBox:~/Bureau/edison-20160606/poky$ make setupSetup buildenv for SDK host linux64
./meta-intel-edison/setup.sh --dl_dir=/home/franck/Bureau/edison-20160606/poky/bbcache/downloads --sstate_dir=/home/franck/Bureau/edison-20160606/poky/bbcache/sstate-cache --build_dir=/home/franck/Bureau/edison-20160606/poky/out/linux64 --build_name=custom_build_franck@20170612110854 --sdk_host=linux64
Clonage dans le dépôt nu 'poky-mirror.git'
fatal: unable to connect to git.yoctoproject.org:
git.yoctoproject.org[0: 140.211.169.56]: errno=Connexion terminée par expiration du délai d'attente
make: *** [setup] Erreur 128
Delay timeout I don't know why, git is install on my liunx (i use Virtual machine linux is
franck@franck-VirtualBox:~$ cat /etc/lsb-release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=14.04
DISTRIB_CODENAME=trusty
DISTRIB_DESCRIPTION="Ubuntu 14.04.5 LTS"
But with bitbake it's start ...?
francknos The real time branch is based on the Intel Edison 2.1 image but with real time patch applied on the 3.10.14 kernel and defconfig set to match. The effect of the patch is to reduce jitter (variable time delays that can happen everywhere in your code or in the kernel) to < 1ms. You pay for this with reduced throughput, f.i. the wifi speed will be cut in half.
Qt: For the morty branch you should be able to use https://layers.openembedded.org/layerindex/branch/morty/layers/ https://layers.openembedded.org/layerindex/branch/morty/layers/ , for dizzy if it works with the original Intel image, it should work now too.
Sorry for the last message :
There was a problem with a firewall.
Now it's compiling...
An other thank you for https://layers.openembedded.org/layerindex/branch/morty/layers/ https://layers.openembedded.org/layerindex/branch/morty/layers/ ihere is a meta-qt more complet than mine.
I'm looking forward to testing this !
I have another question about your project FerryT
If I want include meta-qt5 on my image where do I put the instruction lines?
In offical project I need to put in "edison/build_edison/conf/auto.conf"
IMAGE_INSTALL_append = " qtbase qtbase-fonts \
qtbase-plugins \
qtbase-tools \
qtimageformats-plugins"
And put this in "~/edison/build_edison/conf/bblayers.conf"
${TOPDIR}/../poky/meta-qt5 \
On your project I try to put "/home/franck/Bureau/workspace_edison/meta-qt5 \" in "workspace_edison/out/linux64/build/conf/bblayers.conf"
but if i do "make setup" the file bblayers.conf is re-write and meta-qt5 disappears.
I'm looking for add and remove some packages.
That is correct, I followed the same structure as the Intel image v2.1. I think that was changed in 3.5.
So, you are correct, when running setup the bblayers.conf is reset to original. But normally you would not run setup to often, it also fetches changes to your locally mirrored git repositories. But if you like to stay current with my repository, then the best place to do the edit is in the setup.sh script.
I have never changed anything in auto.conf, what does that?
Anyway, the layers best go in setup.sh.
Packages go in meta-intel-edison/meta-intel-edison-distro/recipes-core/images/edison-image.bb
Or you create your own layer and append edison-image.bb to add specific for your project.
https://github.com/htot/meta-intel-edison meta-intel-edison/https://github.com/htot/meta-intel-edison/tree/master/meta-intel-edison-distro meta-intel-edison-distro/https://github.com/htot/meta-intel-edison/tree/master/meta-intel-edison-distro/recipes-core recipes-core/https://github.com/htot/meta-intel-edison/tree/master/meta-intel-edison-distro/recipes-core/images images/edison-image.bb
Hi, thanks for your reply,
I have build your image successfully.
Now I try to add Qt on edison image.
I choosed to add it in setup.sh like this :
BBLAYERS ?= " \\
$poky_dir/meta \\
$poky_dir/meta-yocto \\
$poky_dir/meta-yocto-bsp \\
$top_repo_dir/meta-intel-edison/meta-intel-edison-bsp \\
$top_repo_dir/meta-intel-edison/meta-intel-edison-distro \\
$poky_dir/meta-intel-iot-middleware \\
$top_repo_dir/meta-intel-edison/meta-intel-arduino \\
$top_repo_dir/meta-qt5 \\
$top_repo_dir/meta-arduino \\
$extra_layers
cd ${top_repo_dir}
echo "Cloning meta-arduino layer to ${top_repo_dir} directory from GitHub.com/01org/meta-arduino"
rm -rf meta-arduino || true
git clone -b 1.6.x https://github.com/01org/meta-arduino.git
cd meta-arduino
git checkout 1.6.x
# clone meta-qt5
cd ${top_repo_dir}
echo "Cloning meta-qt5 layer to ${top_repo_dir} directory from github.com/meta-qt5/meta-qt5/"
rm -rf meta-qt5 || true
git clone -b dizzy https://github.com/meta-qt5/meta-qt5.git
cd meta-qt5
git checkout dizzy
I have take the template of arduino to clone qt.
The "make setup" works well and clone meta-qt5 if not exist on my workspace.
But I think when I do "make image" that qt is not include in the edison image.
I think I need to put some line in "edison-image.bb"
but I don't know exactlly which line .
I tried to put :
IMAGE_INSTALL = " qtbase qtbase-fonts \
qtbase-plugins \
qtbase-tools \
In edison-image.bb, I found this on web but I don't know what it means. This line will install all Qt Framework?
And if I do "make image" with these lines I have errors like :
ERROR: Function failed: do_configure (log file is located at /home/franck/Bureau/workspace_edison/out/linux64/build/tmp/work/core2-32-poky-linux/qtbase/5.3.2-r0/temp/log.do_configure.12191)
ERROR: Logfile of failure stored in: /home/franck/Bureau/workspace_edison/out/linux64/build/tmp/work/core2-32-poky-linux/qtbase/5.3.2-r0/temp/log.do_configure.12191
fatal error: X11/Xlib.h: No such file or directory
| # include
| compilation terminated.
| make: *** [xlib.o] Error 1
| XLib disabled.
| EGL auto-detection... ()
| i586-poky-linux-g++ -m32 -march=core2 -mtune=core2 -msse3 -mfpmath=sse -mstackrealign -fno-omit-frame-pointer --sysroot=/home/franck/Bureau/workspace_edison/out/linux64/build/tmp/sysroots/edison -c -pipe -O2 -pipe -g -feliminate-unused-debug-types -fvisibility-inlines-hidden -O2 -Wall -W -fPIE -I../../../../qtbase-opensource-src-5.3.2/mkspecs/linux-oe-g++ -I../../../../qtbase-opensource-src-5.3.2/config.tests/qpa/egl -I. -o egl.o ../../../../qtbase-opensource-src-5.3.2/config.tests/qpa/egl/egl.cpp
| ../../../../qtbase-opensource-src-5.3.2/config.tests/qpa/egl/egl.cpp:42:21: fatal error: EGL/egl.h: No such file or directory
| # include
| make: *** [egl.o] Error 1
| EGL disabled.
| Warning: Disabling Accessibility. This version of Qt is unsupported.
| No QPA platform plugin enabled!
| If you really want to build without a QPA platform plugin you must pass
| -no-qpa-platform-guard to configure. Doing this will
| produce a Qt that can not run GUI applications.
| The dependencies needed for xcb to build are listed in
| src/plugins/platforms/xcb/README
| WARNING: exit code 1 from a shell command.
ERROR: Task 283 (/home/franck/Bureau/workspace_edison/meta-qt5/recipes-qt/qt5/qtbase_5.3.2.bb, do_configure) failed with exit code '1'
and many other line ...
Which is the way to include all qt framework to my edison image?
Thank you for your time.
What I get from the above message is that there is a dependency on X. So probably you need to set an option somewhere to create headless packages only.
The recipes supported by the layer are here: https://layers.openembedded.org/layerindex/branch/morty/layer/meta-qt5/ https://layers.openembedded.org/layerindex/branch/morty/layer/meta-qt5/
I think the recipe providing the packages you wanted installed is at least qtbase. Looking inside the recipe they use DISTRO_FEATURES to create PACKAGECONFIG*. Then these are used to create the cl options for configuring. I set the DISTRO_FEATURES here https://github.com/htot/meta-intel-edison/blob/master/meta-intel-edison-distro/conf/distro/poky-edis... meta-intel-edison/poky-edison.conf at master · htot/meta-intel-edison · GitHub , but you could also append the recipe.
So, I don't know how to build qt, but I think you do, so you might know what config you need. I suspect this is the real critical message:
but I don't see how to do that. Maybe you should to ask this on the yocto mailing list? They are very helpful and helped me out 2x.
I guess you are experiencing one of my problems too: you want to install an executable, which is inside a package, but you don't know in which package until you've built it. There is probably some clever yocto command to list what's inside, but I don;t know which.
On meta-qt5 page https://layers.openembedded.org/layerindex/branch/morty/layer/meta-qt5/ https://layers.openembedded.org/layerindex/branch/morty/layer/meta-qt5/
Is write :
Dependencies
The meta-qt5 layer depends upon:
So I need to and these layers ?
On these page, http://hobby.farit.ru/qt5-gui-intel-edison/ Qt5 GUI on Intel Edison | Hobby
The Intel Edison has no GPU. So, the Qt OpenGL based modules don't work. Among them are Qt Quick and Qt Declarative and the packages that depend on these two.
On edison/build_edison/conf/auto.conf (I think it's the same as "https://github.com/htot/meta-intel-edison meta-intel-edison/https://github.com/htot/meta-intel-edison/tree/master/meta-intel-edison-distro meta-intel-edison-distro/https://github.com/htot/meta-intel-edison/tree/master/meta-intel-edison-distro/conf conf/https://github.com/htot/meta-intel-edison/tree/master/meta-intel-edison-distro/conf/distro distro/poky-edison.conf")
qtbase-plugins \
qtbase-tools \
PACKAGECONFIG_DISTRO_append_pn-qtbase =
<code class="string cpp" style="font-family: Monaco, Consolas, 'Bitstream Vera Sans Mono', 'Courier New', Courier, mo...
Hi ,
I have an other problem with swig 3.0.6 .bb
in meta-intel-iot-middleware
Error in do_install
in my poky/meta-intel-iot-middleware/recipes-devtools/swig/swig_3.0.6.bb.
i have :
require ${BPN}.inc
SRC_URI += " file://0001-configure-use-pkg-config-for-pcre-detection.patch"
SRC_URI[md5sum] = "df43ae271642bcfa61c1e59f970f9963"
SRC_URI[sha256sum] = "c67f63ea11956106e4cda66416d5020330dc4ce2ee45057d39a9494ce33eca05"
In log file i have
Log data follows:
| DEBUG: Executing shell function do_install
| NOTE: make -j 12 DESTDIR=/home/franck/Bureau/edison-20160606/build_edison/tmp/work/x86_64-linux/swig-native/3.0.6-r0/image install
| make: *** No rule to make target `install'. Stop.
| ERROR: oe_runmake failed
| ERROR: Function failed: do_install (log file is located at /home/franck/Bureau/edison-20160606/build_edison/tmp/work/x86_64-linux/swig-native/3.0.6-r0/temp/log.do_install.717)
No rule to make target install i don't know why.?
Can you help me ?
I think it's the last error.
Hi Francknos,
The steps that I have provided you are the steps to build the Edison's standard image, if you need help following them let us know and we would be glad to help you.
On the other hand, these images are an excellent contribution from FerryT who is a valuable member of this community that has been helping with his projects, nevertheless if you use these images, we won't be able to assist you because they are beyond of our support, but hopefully FerryT will be able to help you here.
Have a nice day.
Leonardo R.
I a reply for your step here :
Hi ,
Error in do_install
i have :
require ${BPN}.inc
In log file i have
Log data follows:
No rule to make target install i don't know why?
Can you help me ?
I think it's the last error. (i hope)
I have delete all files and I restart again from begening.
I make all step you have write here :
build-essential chrpath socat libsdl1.2-dev xterm3. Download and unzip iot-devkit-yp-poky-edison-20160606.zip (http://iotdk.intel.com/src/3.5/edison/iot-devkit-yp-poky-edison-20160606.zip http://iotdk.intel.com/src/3.5/edison/iot-devkit-yp-poky-edison-20160606.zip).
IMAGE_INSTALL += "iotkit-comm-c-dev"5. Go to http://git.yoctoproject.org/cgit/cgit.cgi/meta-java/commit/recipes-core/icedtea/openjdk-7-03b147/sig... http://git.yoctoproject.org/cgit/cgit.cgi/meta-java/commit/recipes-core/icedtea/openjdk-7-03b147/sig..., download the patch and unzip it.
SRC_URI = "<a _jive_internal="true" href="http://sourceforge.net/...
Hi Francknos,
That's weird. I'm going to check it. Could you please tell me which OS you are using? (You can use the command "uname -a").
I will contact you when I have updates, thank you for your patience.
Have a nice day.
Leonardo R.
My distrib is Ubuntu 14.04 LTS
franck@franck-VirtualBox:~$ uname -a
Linux franck-VirtualBox 4.4.0-79-generic # 100~14.04.1-Ubuntu SMP Fri May 19 18:36:51 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
franck@franck-VirtualBox:~$ lsb_release -idc
Distributor ID: Ubuntu
Description: Ubuntu 14.04.5 LTS
Codename: trusty
Hi Francknos,
I was able to build the image with the guide that I have provided you before, now if you have issues with the checksums, you should change the lines 644, 645 in the file /poky/meta-java/recipes-core/openjdk/openjdk-8_60b27-2.5.4.bb for:
SRC_URI[hotspot.md5sum] = "fb166d0a1c1c04c31c872728b92a7636" SRC_URI[hotspot.sha256sum] = "dfda85536353dc0b59ef801f4fe50df1778cbb7dfd0392c9bb9e1d1aa82e75a6"
Let us know if it works.
Have a nice day.
Leonardo R.
Hi ,
I have tried to compile with your modifications of md5sum ...
But I have alaways the same problem the do_fetch doesn't work, the md5sum and sha256sum change every time and i don't konw why.
When I have the error, I have the checksum, I try to recompile, and I have the same error but the checksum change again and every time. I don't konw why ! it's crayz ! And make me annoyed.
The last error is:
ERROR: Fetcher failure for URL: ' http://hg.openjdk.java.net/jdk8u/jdk8u60/hotspot/archive/10ad4b9d79f9.tar.bz2;name=hotspot;unpack=fa...'. Checksum mismatch!
File: '/home/franck/Bureau/edison-20160606/build_edison/downloads/10ad4b9d79f9.tar.bz2' has md5 checksum f0c3b76ba3e67c02045bb1874fcb3848 when cf3ae34a7a4f1aec5fb8a895e3ebf2e4 was expected
File: '/home/franck/Bureau/edison-20160606/build_edison/downloads/10ad4b9d79f9.tar.bz2' has sha256 checksum d1d54c6ff7459cdc8b66b2b14f896fce5eadd53b63adfc45a9b2b7e3ecb5d10c when a95c0a8a20a90f387096dc37d52e4d1e42e5ac9da3c48fbe264d2fd5d79e9ae0 was expected
SRC_URI[hotspot.md5sum] = "f0c3b76ba3e67c02045bb1874fcb3848"
SRC_URI[hotspot.sha256sum] = "d1d54c6ff7459cdc8b66b2b14f896fce5eadd53b63adfc45a9b2b7e3ecb5d10c"
ERROR: Function failed: Fetcher failure for URL: ' http://hg.openjdk.java.net/jdk8u/jdk8u60/hotspot/archive/10ad4b9d79f9.tar.bz2;name=hotspot;unpack=fa...'. Unable to fetch URL from any source.
ERROR: Logfile of failure stored in: /home/franck/Bureau/edison-20160606/build_edison/tmp/work/core2-32-poky-linux/openjdk-8-jre/60b27-2.5.4-r0.1/temp/log.do_fetch.30516
ERROR: Task 1318 (/home/franck/Bureau/edison-20160606/build_edison/../poky/meta-java/recipes-core/openjdk/openjdk-8_60b27-2.5.4.bb, do_fetch) failed with exit code '1'
I have olso try to remove openjdk-8-jre but I have others error and seems to be the same error but with openjdk-7
