Community
cancel
Showing results for
Search instead for
Did you mean:
John_D_Intel
In ISSM Gold, how does the Zephyr CONFIG_QMSI_INSTALL_PATH get configured for External QMSI BSP (1.1.0) ?
Hi, i have modified the prj.conf file to use the (external) QMSI BSP. I cannot seem to get the path parameter set correctly. I have set it in the project properties, and have tried all kinds of syntax in the prj.conf file. I always get the error below (after deleting the outdir folder, clean project, and refreshing each time).
# These are Zephyr project configuration items - to include the QMSI BSP...
CONFIG_QMSI=y
CONFIG_QMSI_INSTALL_PATH=" what goes here ? "
CONFIG_HAS_QMSI=y
CONFIG_QMSI_BUILTIN=n
CONFIG_QMSI_LIBRARY=y
LD ../src/built-in.o
LINK zephyr.lnk
c:/intelswtools/issm_2016.1.067/tools/compiler/gcc-ia/5.2.1/bin/../lib/gcc/i586-intel-elfiamcu/5.2.1/../../../../i586-intel-elfiamcu/bin/ld.exe: cannot find -lqmsi
collect2.exe: error: ld returned 1 exit status
make[2]: *** [.tmp_zephyr.prebuilt] Error 1
make[2]: Leaving directory `/c/IntelSWTools/ISSM_2016.1.067/workspace/Philosophers/outdir'
make[1]: *** [sub-make] Error 2
make[1]: Leaving directory `/c/IntelSWTools/ISSM_2016.1.067/workspace/Philosophers/zephyr'
make: *** [all] Error 2
10:20:27 Build Finished (took 1m:17s.98ms)
Michelle_C_Intel
In Linux I set it to below and the project will build fine.
CONFIG_QMSI_INSTALL_PATH="$(ISSM_BSP_ROOT)/build/release/quark/x86/libqmsi"
However in Windows I am see the same issue you are - It would appear to be an issue with MinGW finding the Library.
I'm currently trying to see if there is a workaround for this so I will let you know...
--Michelle.
Michelle_C_Intel
So it seems it cannot find the library as it is expecting to be called libqmsi.a and that is not the default name when you build it.
(In Linux a symbolic link is created to that is why it was working there).
As a workaround I just made a copy of the file and named it libqmsi.a
To build libqmsi on Windows ....
c:\IntelSWTools\ISSM_2016.1.067>issm_env.bat
Copyright (C) 1985-2016 Intel Corporation. All rights reserved.
Intel(R) Compiler 2016.0 using LLVM technology (package 021)
c:\IntelSWTools\ISSM_2016.1.067>cd %ISSM_BSP_ROOT%
c:\IntelSWTools\ISSM_2016.1.067\firmware\bsp\1.1>make libqmsi SOC=quark_se{or quark_d2000} TARGET=x86 {or sensor}
Then set the CONFIG_QMSI_INSTALL_PATH to the directory where the output file is :
e.g. for quark_se / x86 set it to :
CONFIG_QMSI_INSTALL_PATH="$(ISSM_BSP_ROOT)/build/release/quark_se/x86/libqmsi"
Let me know if this works for you ...
regards,
Michelle.
John_D_Intel
Thanks Michelle !
I got it.
