Intel® Makers
9881 Discussions
Indoor Positioning For Robot
MMasa3
Hi. I want to make an Indoor Positioning system for my robot with Arduino 101 board with Intel Curie module. For marks I want to use beacons. I think I can make beacon from Intel Edison module or buy beacon. But the main problem is how to make program for Intel Curie to use beacons. Maybe you know which literature and articles describe the same task? Maybe someone have already created similar project?
Community Manager
Hello Maksim,
Thank you for interest in the Intel® Curie™ Boards.
I understand that you want to use one Edison module as a beacon and one Curie module as a beacon detector. If that is the case, I'll recommend you to read this article http://www.instructables.com/id/Turn-your-Intel-Edison-in-a-Beacon/, in it, Vitor Leal explains how you can turn your Edison module into a beacon by using its Bluetooth capabilities.
And in order to turn your Curie module into a beacon detector, I suggest this thread https://communities.intel.com/message/417163# 417163 https://communities.intel.com/message/417163# 417163, in it, community member zettez successfully achieves the task of discovering Bluetooth devices with an Edison module (the code that he shared is compatible with your Curie module).
If you need further assistance, don't hesitate to contact us.
And if you can share your experience with the community we will really appreciate it.
Andres
Community Manager
Hello Maksim,
I'll like to know if you had the chance to check the links provided.
In case you did, we would highly appreciate if you would let us know the outcome of these.
Andres
