Community
cancel
Showing results for
Search instead for
Did you mean:
AEl-K
Install Boost on Edison
Hello all,
Did anyone manage to install boost on Edison successfully, as there a lot of packages that fail & get skipped.
Thanks in advance
Sergio_A_Intel
From what repo are you pulling the boost packages? The boost packages are available in AlexT's repo. Follow the instructions here http://alextgalileo.altervista.org/edison-package-repo-configuration-instructions.html Edison Package Repo Configuration Instructions so you can fetch packages from the repo. Use opkg install boost.
Let me know your results.
Sergio
AEl-K
Hey,
Thanks for your reply, fails and skips stoped coming when I installed the 1.58 instead of 1.6 version of boost, I tried these command :
wget http://sourceforge.net/projects/boost/files/boost/1.58.0/boost_1_58_0.tar.gz http://sourceforge.net/projects/boost/files/boost/1.58.0/boost_1_58_0.tar.gz
tar -zxf boost_1_58_0.tar.gz
cd boost_1_58_0/
./bootstrap.sh
./b2 install
From this tutorial http://docs.kaaproject.org/plugins/servlet/mobile# content/view/15796447 http://docs.kaaproject.org/plugins/servlet/mobile# content/view/15796447
Also I tried opkg install boost & opkg install boost-dev
I'm trying to run pip install gattlib but it fails, I have gatttool,pip & boost installed (from the above commands)
So if anyone manged to install gattlib on the Edison successfully please mention the steps.
UPDATE: I have successfully manged to install boost & gattlib on my edison, maybe the problem was that I used opkg install boost & opkg install boost-dev before installing boost 1.58(as mentioned above).
I flashed my edison & reinstalled pip & boost 1.58 & gattlib worked (without needing to use opkg install boost & opkg install boost-dev).
Thank you
