Hi.
I want to see statistics for each protocol (TCP/UDP) on my Galileo Board. I try use netstat -s command (http://www.thegeekstuff.com/2010/03/netstat-command-examples/ UNIX / Linux: 10 Netstat Command Examples).
But i receive error netstat:invalid option -- 's'. It is because BusyBox's netstat version doesn't contain the -s option.
1. Is it possible to install "normal" netstat?
I try to install nettools (which includes netstat) using opkg install, but package manager can't find it.
I also try to compile and install net-tools source from here - https://sourceforge.net/projects/net-tools/ net-tools download | SourceForge.net , but i receive error during installation.
Maybee i can download package from here: http://rpmfind.net/linux/rpm2html/search.php?query=net-tools&submit=Search+...&system=&arch= RPM resource net-tools
2. Is it possible to see statistic without using netstat? (i need information, which command netstat -s returns)
(Example of netstat -s output:
udp:
71208 datagrams received
0 with incomplete header
0 with bad data length field
0 with bad checksum
0 with no checksum
832 dropped due to no socket
16 broadcast/multicast datagrams dropped due to no socket
1971 dropped due to full socket buffers
0 not for hashed pcb
68389 delivered
137685 datagrams output
