Community
cancel
Showing results for
Search instead for
Did you mean:
BWill15
New Contributor II
Install Serial library
I tried to install the Serial library as mentioned by Intel_Alvarado, since there is no Serial preinstalled. I'm using the http://downloadmirror.intel.com/25384/eng/iot-devkit-201510010757-mmcblkp0-galileo.direct.xz EGLIBC microSD card image (210 MB) from https://software.intel.com/en-us/iot/hardware/galileo/downloads IoT - Intel® Galileo Board Download | Intel® Developer Zone.
To use the serial library you can install pyserial. You can see more information on pyserial here https://pypi.python.org/pypi/pyserial https://pypi.python.org/pypi/pyserial . Download the source file and put its contents in the SD card. De compress the folder using tar xvf pyserial-2.7.tar.gz. That will create a folder called pyserial-2.7. Enter that folder and inside it type python setup.py install. Try running the code once again.
root@galileo:/# cd media/
root@galileo:/media# ls
blinkMRAA.py card mmcblk0p1 test.txt testservosMraa.py uartMRAA.py
root@galileo:/media# cd card
root@galileo:/media/card# ls
System Volume Information bzimage pyserial-2.7.tar.gz
boot firmware win-driver
root@galileo:/media/card# tar xvf pyserial-2.7.tar.gz
pyserial-2.7/
pyserial-2.7/test/
pyserial-2.7/test/test_readline.py
pyserial-2.7/test/run_all_tests.py
pyserial-2.7/test/test_advanced.py
pyserial-2.7/test/test_iolib.py
pyserial-2.7/test/test_url.py
pyserial-2.7/test/test.py
pyserial-2.7/test/test_high_load.py
pyserial-2.7/setup.py
pyserial-2.7/CHANGES.txt
pyserial-2.7/PKG-INFO
pyserial-2.7/LICENSE.txt
pyserial-2.7/serial/
pyserial-2.7/serial/serialposix.py
pyserial-2.7/serial/rfc2217.py
pyserial-2.7/serial/serialjava.py
pyserial-2.7/serial/win32.py
pyserial-2.7/serial/__init__.py
pyserial-2.7/serial/sermsdos.py
pyserial-2.7/serial/urlhandler/
pyserial-2.7/serial/urlhandler/protocol_loop.py
pyserial-2.7/serial/urlhandler/protocol_socket.py
pyserial-2.7/serial/urlhandler/__init__.py
pyserial-2.7/serial/urlhandler/protocol_rfc2217.py
pyserial-2.7/serial/urlhandler/protocol_hwgrep.py
pyserial-2.7/serial/serialutil.py
pyserial-2.7/serial/serialcli.py
pyserial-2.7/serial/tools/
pyserial-2.7/serial/tools/list_ports_osx.py
pyserial-2.7/serial/tools/miniterm.py
pyserial-2.7/serial/tools/__init__.py
pyserial-2.7/serial/tools/list_ports_posix.py
pyserial-2.7/serial/tools/list_ports.py
pyserial-2.7/serial/tools/list_ports_windows.py
pyserial-2.7/serial/tools/list_ports_linux.py
pyserial-2.7/serial/serialwin32.py
pyserial-2.7/examples/
pyserial-2.7/examples/tcp_serial_redirect.py
pyserial-2.7/examples/port_publisher.py
pyserial-2.7/examples/setup-miniterm-py2exe.py
pyserial-2.7/examples/wxTerminal.wxg
pyserial-2.7/examples/scanwin32.py
pyserial-2.7/examples/port_publisher.sh
pyserial-2.7/examples/wxSerialConfigDialog.wxg
pyserial-2.7/examples/scan.py
pyserial-2.7/examples/rfc2217_server.py
pyserial-2.7/examples/enhancedserial.py
pyserial-2.7/examples/setup-wxTerminal-py2exe.py
pyserial-2.7/examples/wxSerialConfigDialog.py
pyserial-2.7/examples/setup-rfc2217_server-py2exe.py
pyserial-2.7/examples/wxTerminal.py
pyserial-2.7/examples/scanlinux.py
pyserial-2.7/documentation/
pyserial-2.7/documentation/pyparallel.rst
pyserial-2.7/documentation/appendix.rst
pyserial-2.7/documentation/index.rst
pyserial-2.7/documentation/examples.rst
pyserial-2.7/documentation/pyserial.png
pyserial-2.7/documentation/Makefile
pyserial-2.7/documentation/conf.py
pyserial-2.7/documentation/pyserial_api.rst
pyserial-2.7/documentation/pyserial.rst
pyserial-2.7/documentation/shortintro.rst
pyserial-2.7/MANIFEST.in
pyserial-2.7/README.txt
System Volume Information bzimage pyserial-2.7 win-driver
boot firmware pyserial-2.7.tar.gz
root@galileo:/media/card# cd pyserial-2.7
root@galileo:/media/card/pyserial-2.7# python setup.py
/usr/lib/python2.7/distutils/dist.py:267: UserWarning: Unknown distribution opti on: 'use_2to3'
warnings.warn(msg)
usage: setup.py [global_opts] cmd1 [cmd1_opts] [cmd2 [cmd2_opts] ...]
or: setup.py --help [cmd1 cmd2 ...]
or: setup.py --help-commands
or: setup.py cmd --help
error: no commands supplied
Sergio_A_Intel
The last command is python setup.py install not python setup.py.
The last lines of the output should look something similar to this:
running install_scripts
copying build/scripts-2.7/miniterm.py -> /usr/bin
changing mode of /usr/bin/miniterm.py to 755
running install_egg_info
Writing /usr/lib/python2.7/site-packages/pyserial-2.7-py2.7.egg-info
Sergio
BWill15
New Contributor II
Decompress the folder using:
Enter that folder:
cd pyserial-2.7
Inside it type:
Sergio_A_Intel
Yes, those are the steps. Did they work for you?
Sergio
BWill15
New Contributor II
Yes, it worked. Thank you. I made a clear distinction between the commands and the text since i thought "install" was a part of the sentence.
