I've gone through various discussions on the same website. I'm trying to install TensorFlow on my Intel Edison. Getting errors.
Previously people are getting errors too (As per the discussion i've read).
Any success in the same till now?
Hi, shruticode
Thank you for your interest in the Intel Edison board.
Could you please give me more details about your issue?
What operating system are you using?
What errors are you getting?
Which guide are you following?
Alexandra
Hello Alexandra,
I'm using Yocto OS image version 201606081705.
I'm following guide can be found here : https://gist.github.com/kmhofmann/e368a2ebba05f807fa1a90b3bf9a1e03 Building TensorFlow from source · GitHub
I'm finding error during bazel compilation stage. First few errors are occurring and at last it showing me out of Resources.
Shruti
Hi shruticode,
It seems like the board might be running out of memory/space. I'd suggest you to try adding extra space to the build process like a micro-SD card or USB flash drive.
I also found this thread online https://github.com/bazelbuild/bazel/issues/1308 https://github.com/bazelbuild/bazel/issues/1308 that might be helpful. It seems related to the system running out of memory, you should try it.
Alexandra
Hi shruticode,
Do you still need help with this issue?
Alexandra
I am using Intel Edison with Sparksfun base and GPIO blocks. I'm using OTG cable provided by a kit from sparksfun only. I'm attaching Sandisk micro sd card via iball micro sd card adapter .
I am getting the following errors.
usb 1-1: device descriptor read/8, error -110
unable to enumerate USB device on port 1
Please, help me. What should i do ?
Shruti.
Hi shruticode,
You should check the power supply, the voltage might be too high. Ideally it should be 5V.
Also, try reflashing the board and format the SD card. You can also use an USB hub and insert the SD card adapter in the hub instead of directly in the board.
Let me know if it works.
Alexandra
Hi shruticode,
Alexandra
Hello Alexandra,
Yeah, it was some issue regarding voltage differance problem. Issue got solved. Thanks for helping. Anyway, Bazel is required for installing Tensorflow. Bazel only supports 64 bit os. Intel Edison have 32 bit os only. Tensorflow may be not be installed on this board.
shruticode
