Community
cancel
Showing results for
Search instead for
Did you mean:
KNguy20
Install TensorFlow on Intel Edison
Does anyone know how to install TensorFlow on Intel Edison ?
The application model which was built by tensorflow on linux, will run on Intel Edison.
Thank you and regards
Khoa
KMill10
Valued Contributor II
I haven't tried this myself but the procedure should be like this:
Install tensorflow by entering the following from a command line on Edison:
$ git clone https://github.com/tensorflow/tensorflow.git https://github.com/tensorflow/tensorflow.git
$ cd tensorflow
$ ./configure
$ make
$ make install
Community Manager
Hi Khoa,
Do you have any updates about this? Did you tried SpiderKenny suggestion?
-Leonardo
KMaje
Hi all,
Tensorflow uses Bazel build which does not have binaries for Edison.
The first step is to install numpy - this works, numpy is compiled on target, on the fly.
if you run ./configure there is problem with sed: (using all default options or all No options)
Found possible Python library paths:
/usr/lib/python2.7/site-packages
Please input the desired Python library path to use. Default is [/usr/lib/python2.7/site-packages]
Using python library path: /usr/lib/python2.7/site-packages
sed: unmatched '['
You can use https://github.com/tiny-dnn/ tiny-dnn · GitHub instead [have not tested it yet]
Karol
Community Manager
This idea sounds absolutely awesome, and if there is any progress please let us know.
KNguy20
Hi all,
I was busy so I didn't check mail.
It seems tensorflow hasn't supported Intel Edison yet.
So i'm currently using tensorflow on my Raspberry pi 2.
Khoa
KMaje
tiny-dnn works on Edison 32bit
keras with theano backend also works on Edison 32bit
