Community
cancel
Showing results for
Search instead for
Did you mean:
WMa2
Installation error. Integrity fail
I just got the board 2 days ago and I am newly installing the driver.
I got this error which I don't know how to fix.
please see attachment.
PBear1
Getting the same error when installing on a new laptop. looks like its something to do with the license rtf file.
to get you up and running
download the individual parts ide you want firmware image and install them as in the user guides
WMa2
I did you told still not completely fix.
Community Manager
Hi InnovatorPrime,
Following the suggestion from paulbearne, you can install the drivers manually with the following guide: https://software.intel.com/en-us/get-started-edison-windows-32-step2 https://software.intel.com/en-us/get-started-edison-windows-32-step2
If you are still getting issues when installing the drivers manually, post a screenshot of the error message so we can help you with it.
Diego
WMa2
i got this integrety check error
WMa2
hey I tried to I don't get how that flash-tool-lite work
Community Manager
Hi InnovatorPrime,
Did you follow the guide I linked above? From your pictures, I see that you are not installing the drivers manually. The driver you have to install is the following: http://downloadmirror.intel.com/24909/eng/IntelEdisonDriverSetup1.2.1.exe http://downloadmirror.intel.com/24909/eng/IntelEdisonDriverSetup1.2.1.exe
Regarding the Flash Tool Lite, you can download it from the following site: https://software.intel.com/en-us/iot/hardware/edison/downloads https://software.intel.com/en-us/iot/hardware/edison/downloads. Then, follow this guide to install the software: https://software.intel.com/en-us/articles/flash-tool-lite-user-manual https://software.intel.com/en-us/articles/flash-tool-lite-user-manual
Diego
WMa2
Hey Diego:
The driver was successful but
I got these error when I try to flash the Edison board.
4/06/16 23:20:14.699 INFO : [Port -1] Starting flash ...
04/06/16 23:20:14.699 INFO : [Port -1] Running `Notify` command
04/06/16 23:20:14.745 INFO : Displaying notification during 42000 ms
04/06/16 23:20:14.747 INFO : [Port -1] Command `Notify` succeed
04/06/16 23:20:14.747 INFO : [Port -1] Running `Wait for device with status dnx_fw on port -1` command
04/06/16 23:20:56.748 ERROR : [Port -1] Command `Wait for device with status dnx_fw on port -1` failed
04/06/16 23:20:56.748 ERROR : [Port -1] Flash failed (Command type: Device enumeration)
WMa2
Some flash install also fail but with different messages.
04/07/16 00:21:39.955 INFO : [Port 1/1/6] Start flashing the flash configuration with dnx_fw start state for E6AFF6E1E5907B1E73DD135962D0E95E
04/07/16 00:21:39.956 INFO : [Port 1/1/6] Starting flash ...
04/07/16 00:21:39.956 INFO : [Port 1/1/6] Running `Notify` command
04/07/16 00:21:40.304 INFO : Displaying notification during 42000 ms
04/07/16 00:21:40.324 INFO : [Port 1/1/6] Command `Notify` succeed
04/07/16 00:21:40.325 INFO : [Port 1/1/6] Running `Wait for device with status dnx_fw on port 1/1/6` command
04/07/16 00:21:40.325 INFO : [Port 1/1/6] Command `Wait for device with status dnx_fw on port 1/1/6` succeed
04/07/16 00:21:40.325 INFO : [Port 1/1/6] Running `Notify` command
04/07/16 00:21:40.334 INFO : Displaying notification during 5000 ms
04/07/16 00:21:40.335 INFO : [Port 1/1/6] Command `Notify` succeed
04/07/16 00:21:40.335 INFO : [Port 1/1/6] Running `"xfstkFlashTool.exe" "-1" "C:\Users\wenboma\Downloads\iot-devkit-prof-dev-image-edison-20160315\edison_dnx_fwr.bin" "C:\Users\wenboma\Downloads\iot-devkit-prof-dev-image-edison-20160315\edison_ifwi-dbg-00.bin" "C:\Users\wenboma\Downloads\iot-devkit-prof-dev-image-edison-20160315\edison_dnx_osr.bin" "C:\Users\wenboma\Downloads\iot-devkit-prof-dev-image-edison-20160315\u-boot-edison.img" "0x80000007" "none" "none" "0"` command
04/07/16 00:21:40.356 INFO : [Port 1/1/6] Disabling xFSTK Misc DnX
04/07/16 00:21:40.356 INFO : [Port 1/1/6] Disabling xFSTK wipe out ifwi option
04/07/16 00:21:40.356 INFO : [Port 1/1/6] Using xFSTK Solo interface (new API)
04/07/16 00:21:40.356 INFO : [Port 1/1/6] xFSTK Soft Fuse not set
04/07/16 00:21:40.356 INFO : [Port 1/1/6] XFSTK Downloader API 1.8.1
04/07/16 00:21:40.356 INFO : [Port 1/1/6] Copyright (c) 2015 Intel Corporation
04/07/16 00:21:40.356 INFO : [Port 1/1/6] fwdnx -- C:\Users\wenboma\Downloads\iot-devkit-prof-dev-image-edison-20160315\edison_dnx_fwr.bin
04/07/16 00:21:40.356 INFO : [Port 1/1/6] fwimage -- C:\Users\wenboma\Downloads\iot-devkit-prof-dev-image-edison-20160315\edison_ifwi-dbg-00.bin
04/07/16 00:21:40.356 INFO : [Port 1/1/6] osdnx -- C:\Users\wenboma\Downloads\iot-devkit-prof-dev-image-edison-20160315\edison_dnx_osr.bin
04/07/16 00:21:40.356 INFO : [Port 1/1/6] osimage -- C:\Users\wenboma\Downloads\iot-devkit-prof-dev-image-edison-20160315\u-boot-edison.img
04/07/16 00:21:40.356 INFO : [Port 1/1/6] gpflags -- 0x80000007
04/07/16 00:21:40.356 INFO : [Port 1/1/6] softfuse --
04/07/16 00:21:40.366 INFO : [Port 1/1/6] XFSTK-STATUS--Detecting Intel Device - Attempt # 0
04/07/16 00:21:41.496 INFO : [Port 1/1/6] XFSTK-STATUS--Detecting Intel Device - Attempt # 1
04/07/16 00:21:42.626 INFO : [Port 1/1/6] XFSTK-STATUS--Detecting Intel Device - Attempt # 2
04/07/16 00:21:43.756 INFO : [Port 1/1/6] XFSTK-STATUS--Detecting Intel Device - Attempt # 3
04/07/16 00:21:44.386 INFO : [Port 1/1/6] XFSTK-STATUS--Detecting Intel Device - Attempt # 4
04/07/16 00:21:45.517 INFO : [Port 1/1/6] XFSTK-STATUS--Detecting Intel Device - Attempt # 5
04/07/16 00:21:46.647 INFO : [Port 1/1/6] XFSTK-STATUS--Detecting Intel Device - Attempt # 6
04/07/16 00:21:47.777 INFO : [Port 1/1/6] XFSTK-STATUS--Detecting Intel Device - Attempt # 7
04/07/16 00:21:48.407 INFO : [Port 1/1/6] XFSTK-STATUS--Detecting Intel Device - Attempt # 8
04/07/16 00:21:49.537 INFO : [Port 1/1/6] XFSTK-STATUS--Detecting Intel Device - Attempt # 9
04/07/16 00:21:50.667 INFO : [Port 1/1/6] XFSTK-STATUS--Detecting Intel Device - Attempt # 10
04/07/16 00:21:51.797 INFO : [Port 1/1/6] XFSTK-STATUS--Detecting Intel Device - Attempt # 11
04/07/16 00:21:52.427 INFO : [Port 1/1/6] XFSTK-STATUS--Detecting Intel Device - Attempt # 12
04/07/16 00:21:53.557 INFO : [Port 1/1/6] XFSTK-STATUS--Detecting Intel Device - Attempt # 13
04/07/16 00:21:54.687 INFO : [Port 1/1/6] XFSTK-STATUS--Detecting Intel Device - Attempt # 14
04/07/16 00:21:55.817 INFO : [Port 1/1/6] XFSTK-STATUS--Detecting Intel Device - Attempt # 15
04/07/16 00:21:56.447 INFO : [Port 1/...
Community Manager
Hi InnovatorPrime,
Could you take a screenshot of the Device Manager while the USB port is connected to the PC? I'd like to check the status of the COM port and confirm that the Edison is recognized. If the board is recognized, you should see the Edison drive in Windows Explorer when the USB cable is connected to the PC.
Additionally, I recommend you to try using an alternative method to flash the Edison. This method uses a script called flashall. The process is described in the following document: /docs/DOC-25154 https://communities.intel.com/docs/DOC-25154. If there is an error during the process, please take a screenshot so I can check the error message.
Diego
WMa2
I do see the COM port
WMa2
C:\Users\wenboma\Downloads\iot-devkit-prof-dev-image-edison-20160315>flashall.ba
t
Using U-boot target: edison-blankrndis
Now waiting for dfu device 8087:0a99
Please plug and reboot the board
Dfu device not found Timeout
Did you plug and reboot your board?
If yes, please try a recovery by calling this script with the --recovery option
i tried the instruction but they don't recognize the board it seems. it time out
Community Manager
Hi InnovatorPrime,
Did you reboot the board? When running the flashall script, you have to unplug the power source and then plug it again. The flashall script should recognize the board during the booting process. Also, make sure you have copied the dfu-util.exe file in the same directory where the image files are located, otherwise you will get an error.
Diego
WMa2
Hey Diego:
The flashell.sh worked. I have to reset by flipping the USB switch unplugging the power was not enough. What is my next step?
WMa2
The Intel Edison USB Composite Device COM Port is missing how do i fix that?
Community Manager
Hi InnovatorPrime ,
If you are on Windows, you have to use the flashall.bat file, not the flashall.sh file. Could you please take a screenshot of the flashing process status? I'd like to check what the outcome is.
In order to check if you have flashed the Edison successfully, run the following command in the Edison's console: cat /etc/version. The following guide will show you how to access the Edison's console: https://software.intel.com/en-us/get-started-edison-windows-32-step5 https://software.intel.com/en-us/get-started-edison-windows-32-step5.
Additionally, make sure you have installed the drivers required for the USB and Serial ports: https://software.intel.com/en-us/get-started-edison-windows-32-step2 https://software.intel.com/en-us/get-started-edison-windows-32-step2. You should have them installed by now, but run the installers again just to be sure. Please provide a screenshot of the installation message of the USB driver.
Diego
WMa2
Hey Diego:
here is the CMD when i installed the flashall.bat
I installed the USB driver already. I don't know if it worked.
Community Manager
Hi InnovatorPrime,
According to the screenshot, it seems that the flashing process ended successfully. In order to check if the Edison was flashed with the latest image, run the following command in the Edison's console: cat /etc/version.
To access the Edison's console, you have to use a software called PuTTY. The process of accessing the Edison's console is described in the following guide: https://software.intel.com/en-us/get-started-edison-windows-32-step5 https://software.intel.com/en-us/get-started-edison-windows-32-step5
Please take a screenshot of the Edison's console when running the command above.
Diego
WMa2
The serial connection didn't work. No asking for Login just blank. I use COM7.
I also installed the usb driver.
Community Manager
Hi InnovatorPrime,
That's weird, considering the fact that the latest image was flashed successfully. Could you confirm if you are still seeing the "Intel Edison Virtual Com Port" and "USB Serial Port" ports only? You should also see another COM port labeled as "Intel Edison USB Composite Device".
Anyhow, if you have installed the drivers and flashed the image, but you are not able to access the Edison's console, I recommend you to contact the place of purchase and explain the issue to them. If I'm not mistaken you got the module recently so they should help you if you are still under their warranty period.
Other option, in case the place of purchase don't contact you back, is to open a warranty ticket using the following form: https://customercare.intel.com/?lang=en-US https://customercare.intel.com/?lang=en-US. The Warranty Team will contact you as soon as they receive your ticket, however, I recommend you to contact the place of purchase first since you got the board recently.
Diego
WMa2
So after the flash should. Should the edison board still show as a storage device? I just reinstalled it.
How much space does the edison left after the flash?
What does the 5 button at the top left corner of the board do? Does it affect the flash or what is saved in the cpu?
I can see the intel composite device now. I have deleted and reinstall all the stuff. however the USB Serial Port is now missing. Do I need a reboot?
