Intel® Makers
9881 Discussions
Installation of kernel module for USB driver (cp210x)
NK
I am actually following the home automation using galileo book to install the driver of cp210x family.
I was successfully able to transfer the kernel ipk module built on my system to the galileo through scp
Bu when I type the "opkg install "
It was showing the following error:(screen shot also attached below)
root@galileo:~# opkg install kernel-module-cp210x_3.14-r0_quark.ipk
Installing kernel-module-cp210x (3.14-r0) on root.
Collected errors:
* satisfy_dependencies_for: Cannot satisfy the following dependencies for kernel-module-cp210x:
* kernel-3.14.28-ltsi-yocto-standard *
* opkg_install_cmd: Cannot install package kernel-module-cp210x.
root@galileo:~#
Pedro_M_Intel
Hello KS_Nathan,
According to the error message you received, the reason why you can't install the driver is because it requires kernel 3.14 to work. If you are using Galileo's official image, it doesn't meet this requirement as it uses kernel 3.8.7. Nevertheless, you could build your own image (and include the driver while doing it) that uses kernel 3.14. In order to do so you will have to use https://downloadcenter.intel.com/download/23197/Intel-Quark-BSP Quark's BSP 1.2.1 and follow http://www.intel.com/content/dam/www/public/us/en/documents/release-notes/quark-x1000-bsp-build-sw-r... its building guide.
Peter.
Pedro_M_Intel
Hello KS_Nathan,
Peter.
NK
Thank you for the early response, I will try it out..
