Intel® Makers
9881 Discussions
Installing SPP-loopback
KWinn
Hi ...
I been working on intel Edison Bluetooth and cannt connect from my phone to Edison but from Edison I cant connect to my phone and can pair it .
I download the light blue app from app store and try to scan for my Edison board ,its show nothing and I try to check it out on web for whats the error and I found out that my UUID: serial port is missing on Edison board .Downloaded the spp-loopback.py file and put it inside my Edison board under sketch folder and use putty software to run it . But its not working and keep getting error ,it seems like I cannt run spp-loopback file. Any one can help me with this problem. Thanks for your help and appreciate it
ABHIROOP_K_Intel
Have you checked if the BT adaptor is on?
https://software.intel.com/en-us/articles/intel-edison-board-getting-started-with-bluetooth IoT - Intel® Edison Board Getting Started with Bluetooth* | Intel® Developer Zone
KWinn
yes ..I alr checked
and I follow this steps and try to make it work but I stuck at steps 18
KWinn
I downloaded the spp pro app and try to scan for my Edison board
i can see my Edison board but cannt make the connection sucessfully
but I can pair and connect from Edison to my phone with my built-in Bluetooth from phone
thanks for ur help:)
Community Manager
Hello kaungthantwinn,
The reason why you are getting that output is because you are entering the file address incorrectly, your command is python sketch/SPP-loopback.py -c 22 when it should be python /sketch/SPP-loopback.py -C 22.Try it this way and let me know.
Also I noticed that in the command you use the option -c, that's not correct, you should use the option -C.
Peter.
KWinn
Hi peter
Thanks for your help . I try this command python /sketch/SPP-loopback.py -C 22 but i still getting error
Community Manager
The command you entered this time seems fine but the error message you receive isn't. I believe the file of SPP-loopback.py might be corrupted or maybe the code wasn't pasted correctly. How did you put this file into your board?
Anyway, you could try to download it again to see if it helps. Follow these steps to do so:
1. Connect your board to the internet. In case you haven't done it already, you can set the Wi-Fi interface with the command configure_edison --wifi
2. Go to the directory where you would like to store the file, in your case /sketch. Use the command cd /sketch.
3. Delete the old SPP-loopback.py file with the command rm SPP-loopback.py.
4. Download the new SPP-loopback.py file with the command wget http://downloadmirror.intel.com/24909/eng/SPP-loopback.py http://downloadmirror.intel.com/24909/eng/SPP-loopback.py.
Now try to follow the guide again.
Peter.
KWinn
Hi Mr.peter
I deleted the old SPP file, i connect my board to internet and downlaod the new SPP file as ur guide.
last time i use WinSCP to put the file inside my board but this time i downloaded to my board.
When i run this command python /sketch/SPP-loopback.py -C 22 its just stuck,i wait for like 15 minutes also not moving just stuck at the command
i really appreciate for ur help sir
Community Manager
When you ran the command, were you connected to an Android device? Did you follow all the steps in for this last test?
Peter.
KWinn
HI peter
Its work
Thanks for ur help
