Community
cancel
Showing results for
Search instead for
Did you mean:
JGoet1
Inte Compu Stick STCK1A32WFCL
Hello, my compute stick cannot read SD card type SanDisk Ultra 128GB SD XC 1, Only via USB adabter.
What's,the,problem.
Community Manager
Hi Pink: Thank you very much for contacting the Intel® Compute Stick communities. We are sorry to hear the stick is not working as expected.
In regard to this scenario, it is hard to tell for sure what might be the source of the problem, it could be a hardware problem with the SD Card slot on the Intel® Compute Stick itself. According to the TPS (Technical Product Specification) of the unit, the stick should be able to read a 128GB SDXC Card, please check page 18:
https://www.intel.com/content/dam/support/us/en/documents/boardsandkits/computestick/STCK1A32WFC-STC... https://www.intel.com/content/dam/support/us/en/documents/boardsandkits/computestick/STCK1A32WFC-STC...
That SD Card, did it work fine before, was it properly detected by the Compute Stick?
By any chance, do you have the option to test a different SD Card on the stick?
We can also try a BIOS update to the latest version, 0035, using the F7 method:
https://www.intel.com/content/www/us/en/support/articles/000006039/mini-pcs/intel-compute-sticks.htm...
https://downloadcenter.intel.com/download/26540/BIOS-Update-FCBYT10H-86A-?product=86612 https://downloadcenter.intel.com/download/26540/BIOS-Update-FCBYT10H-86A-?product=86612
Any further questions, please let me know.
Alberto R
Community Manager
Pink: I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Alberto R
JGoet1
No this problem is not resolved, But there are problems in Device Manager.
PCI -controller Decrypt/Encrypt
The drivers for this device are not installed. (Code 28)
I2C- controller for Intel atom Proecessors
There are no compatible drivers for this device.
Click Update driver to a driver for this device.
This device is not working properly because Windows cannot load the drivers required for this device. (Code 31)
The i/o device is configured incorrectly or the configuration data for the driver are incorrect.
https://www.intel.com/content/www/us/en/support/articles/000006039/mini-pcs/intel-compute-sticks.htm... https://www.intel.com/content/www/us/en/support/articles/000006039/mini-pcs/intel-compute-sticks.htm...
https://downloadcenter.intel.com/download/26540/BIOS-Update-FCBYT10H-86A-%3Fproduct%3D86612 https://downloadcenter.intel.com/download/26540/BIOS-Update-FCBYT10H-86A-?product=86612
<span style="margin: 0px; font-...
Community Manager
Pink: Thank you very much for letting us know those results, we are sorry to hear the problem persists.
To try to fix those problems, the next thing we can try will be to re-install the SOC driver:
https://downloadcenter.intel.com/download/25311/Compute-Stick-System-on-a-Chip-SOC-Driver-Package-fo... https://downloadcenter.intel.com/download/25311/Compute-Stick-System-on-a-Chip-SOC-Driver-Package-fo...
Did you tried the BIOS update?
Do you have the option to test a different SD card?
Alberto R
JGoet1
Ok thanks, the problems are resolved and now can read the SD card in the Compu Stick (backside)
Jeroen
Community Manager
Pink: Perfect, thank you very much for letting us know that information, it is great to hear that the problem got fixed and now the stick can read the SD card.
Alberto R
