Intel® Makers
9880 Discussions
Intel Analytics REST API returns HTML login page instead of JSON data
JFaul1
I am trying to test the REST API with Postman. Receiving the authorization token works fine, but if I want to sent or receive data from the cloud I get 200 status code and the HTML of the dashboard.enableiot.com login page:
<!DOCTYPE html>
IoT Analytics Dashboard
{{i18n.app_title}}
BETA
For the request i followed the instructions found here: https://github.com/enableiot/iotkit-api/wiki/Data-API Data API · enableiot/iotkit-api Wiki · GitHub
My request to send data looks like this, all the IDs (account, device, component) are changed to the IDs I found on the dashboard website:
POST /data/ HTTP/1.1
Host: dashboard.us.enableiot.com
Content-Type: application/json
Authorization: Bearer
Cache-Control: no-cache
Postman-Token:
"on": 1354741967799,
"accountId": "550e8400-e29b-41d4-a716-446655440000>",
"data": [
"componentId": "436e7e74-6771-4898-9057-26932f5eb7e1>",
"on": 1354741966688,
"value": "3...
Sergio_A_Intel
Hi user_1234,
Before sending data make sure you have already followed https://github.com/enableiot/iotkit-agent GitHub - enableiot/iotkit-agent: Edge agent to abstract cloud connectivity complexities . Make sure you are using the latest version as well.
Have you already checked the Connecting to IoT Analytics via REST API section and the sample codes available for Python and JavaScript? See more here: https://software.intel.com/en-us/intel-iot-platforms-getting-started-cloud-analytics Intel® IoT Platforms: Getting Started: Cloud Analytics | Intel® Developer Zone
I also found a similar thread to yours. Look at
Sergio
JFaul1
Hi Sergio,
Thanks a lot for your help. The python code helped, as I realized after going through the code that my URL was simply missing "/v1/api". It has to be:
https://dashboard.us.enableiot https://dashboard.us.enableiot/v1/api/data/
In my opinion this is not very obviously stated in the API documentation on Github, as the /v1/api part is added in the Doku in the REST url to get the token but not for the Data API.
Thank you.
Julia
