I am using Intel's System Studio iot edition. when i attempt to run the program "Quick start Intel Cloud" i keep getting
root@galileo:~# chmod 755 /tmp/IntelCloud;/tmp/IntelCloud ;exit
/tmp/IntelCloud: error while loading shared libraries: libpaho-mqtt3c.so.1: cannot open shared object file: No such file or directory
logout
- Tags:
- Cloud Computing
Hello JimmyIsTheBoss,
Thanks for reaching out!
It seems that you are trying to use the example that used Intel's Cloud service, am I right? If so, the reason why this example is failing is explained in https://communities.intel.com/thread/107871 https://communities.intel.com/thread/107871. As you can see in that thread, Intel® Cloud Analytics have been discontinued, nevertheless, there are some alternatives that are compatible with Galileo. You can find them in: https://software.intel.com/en-us/iot/hardware/edison under the section Connect with MQTT.
I hope this helps.
-Peter.
