Community
cancel
Showing results for
Search instead for
Did you mean:
FPINH
Intel® Compute Stick STK1A32SC BIOS is it DEAD?
I interrupted the BIOS update process.
Now, MY BIOS IS IT DEAD?
Using BIOS Recovery Instructions for Intel® Compute Stick https://www.intel.com/content/www/us/en/support/boards-and-kits/intel-compute-stick/000005902.html https://www.intel.com/content/www/us/en/support/boards-and-kits/intel-compute-stick/000005902.html:
  • 2. Plug the USB device into a USB port of the Intel Compute Stick when it is turned off (not in Hibernate or Sleep mode). If you're using a USB keyboard/mouse, you will need a multiport USB hub.
  • 3. Press and hold the power button down for 3 seconds. Release it before the 4-second shutdown override.
NOT WORK!!!
My monitor-tv HDMI port not receive signal.
Please, can you help me?
Community Manager
Hello Francisco6x,
My apologies for the inconvenience.
Are you doing the recovery with BIOS 035?
Have you tried testing a different power adapter?
Is there any chance to test a different HDMI port?
Amy C.
FPINH
Hello Amy.
Yes. SC0035.bio.
Yes.
Yes. I tested it in another monitor-tv that it uses another STK1AW32SC.
Community Manager
Based on your description and troubleshooting it seems like the unit is bricked, so the at this stage the next will be replacing the unit. Please contact us directly using our contact options in order to check the warranty options for your unit: https://www.intel.com/content/www/us/en/support/contact-support.html Contact Support
Again, my apologies for the inconvenience caused.
Amy C.
FPINH
Hello Amy
Service request https://supporttickets.intel.com/requestdetail?id=5000P00000cNmhnQAC&lang=en-US 03012872 has been opened and is being addressed by your team.
Please, help me!
Community Manager
I noticed that an agent is now working on your case, for future reference refer to that case number.
Amy C.
FPINH
Thank you, Amy.
