Intel® Makers
9881 Discussions
Intel Compute Stick Win10 32 bit
MTonn
someone an idea how to fix DNS problems on integrated Wifi Adapter ?
using an AVM FritzBox! fom 1 & 1 and on all other devices it works fine.
Using Intel Compute stick i cant get connected , DNS errors.
Also i used other Wifi Routers there are no problems.
I tried out other DNS servers, but that didnt helps, Flushing DNS , no difference.
What could be the reason for this DNS problem? Are there fixes for Download ?
Thank You
Anonymous
Not applicable
Hi Viterbese,
Could you please tell me more about the issue? Please send me examples of the problem.
As a workaround, review if you are already using the latest BIOS and drivers.
https://downloadcenter.intel.com/product/86612/Intel-Compute-Stick-STCK1A32WFC Downloads for Intel® Compute Stick STCK1A32WFC
Mike C
MTonn
Hello Mike,
I have the latest BIOS version installed.
I will describe this problem:
After connecting with my Router ( AVM Fritzbox 7312 ) , the connection to WiFi works fine.
But it cant connect to Internet because the Wifi Adapter cant connect to standardgateway( Router)
DHCP works fine, but i cant ping the Router. Browser displayed an DNS Error.
So i tried out with a static IP, but its the same, no connection to gaateway.
I flushed DNS , relaesed and renewd connections, nothing changed.
My Router works fine with any other device, only my Intel Computer Stick do not.
Trying out tethering on my smartphone, the stick works fine again. Using other routers, works fine too.
Its a problem with FritzBox 7312 and the Compute Stick in general ?
Thanks fpr your affort
Greatings
Marco
Anonymous
Not applicable
Hi Viterbese,
I suggest you to reset the Router to default settings and check the behavior. Please verify if you are using the latest BIOS and drivers. Verify if you already have the latest firmware on your Router AVM Fritzbox 7312.
https://downloadcenter.intel.com/product/86612/Intel-Compute-Stick-STCK1A32WFC Drivers & Software
Mike C
