Intel® Makers
Intel® Edison, Intel® Joule™, Intel® Curie™, Intel® Galileo
Welcome - This is a Peer-to-Peer Forum only. Intel has discontinued these products but you may find support from other customers on this Forum
9876 Discussions
Intel Compute Stick goes to sleep everyday.
akole4
Good day,
I have Intel Compute Stick ,which connected to TV and it displays some Important Information (OS w8.1).
Sometimes (usually once a day,at night) device goes to sleep and isn't responding by ping, display shows nothing. Blue light is on.
Power button helps to wake up device.
There is no some scheduled scripts. only 1 application at startup.
Switching off the display Power-saving option in the Intel HD Graphics didn't solve the problem
In power options i have balanced plan (it's the only plan which i can see here) and option "put the computer to sleep" - "never"
In advanced options "turn off the display" set to "never" too.
Device is powered by default usb adapter,not from TV.
Please help me to solve this problem
TSand7
You need to make a change in Registry.
HKLM\System\CurrentControlSet\Control\Power\ and change the value of CsEnabled from 1 to 0
This stops PC from going into Connected Standby mode
TSand7
