Intel® Makers
9881 Discussions
Intel Curie Project - Help needed
KSels
New Contributor II
Can the Intel Curie handle scheduler commands?
Task no. 1
Start/Stop GPS data saving to SD card from button or phone command.
Task no. 2
Communicate to smart phone to transfer sd card files to smart phone.
Community Manager
Hi KimLorentz,
Thanks for your interest in the Intel Curie Platfom.
The Intel Curie is integrated with a RTC and Timers, you might be able to take advantage of this hardware resources to achieve the tasks you have design for your project. I leave here the link for the datasheet of the Intel Curie ( https://software.intel.com/en-us/articles/intel-curie-module-datasheet). I hope you find this information useful.
I will be waiting for your reply, have a nice day.
-Jose.
KSels
New Contributor II
Tryed using the scheduler command, it gives no error but it does not work on the Curie.
Also been working on Bluetooth services. I found a loot of them and was wondering what type of service do I use for Serial to Bluetooth and to get a data dump.
https://www.bluetooth.com/specifications/gatt/services GATT Services
https://www.bluetooth.com/specifications/gatt/viewer?attributeXmlFile=org.bluetooth.service.object_t... Transfer Service
https://www.bluetooth.com/specifications/gatt/viewer?attributeXmlFile=org.bluetooth.service.user_dat... User Data
FileDump coding.
# include
# include
const int chipSelect = 8;
void setup() {
// Open serial communications and wait for port to open:
Serial.begin(115200);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.print("Initializing SD card...");
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
// don't do anything more:
return;
Serial.println("card initialized.");
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
File dataFile = SD.open("datalog.txt");
// if the file is available, write to it:
if (dataFile) {
while (dataFile.available()) {
Serial.write(dataFile.read());
dataFile.close();
// if the file isn't open, pop up an error:
else {
Serial.println("error opening datalog.txt");
void loop() {
Community Manager
Hi KimLorentz,
I see that you are using the Arduino 101, at the moment the scooped of our support is limited for only the Curie ODK. Nevertheless I have found this link that might be useful for you: (https://forum.arduino.cc/index.php?topic=208306.0 File transfer via Bluetooth Serial Communication ).
I will strongly suggest to contact the Arduino Community, you can find it in this link: (http://forum.arduino.cc/ Arduino Forum - Index ).
-Jose.
