Intel® Makers
9880 Discussions
Intel Curie freezes when getting Acc and Gyro data
LSous2
Bought 2 recent Intel Curie to transmit Acc and Gyro data over BLE and it freezes every time after a few minutes.
Even using RawImuDataSerial arduino examples.
Did a little search and it seems it has a problem over I2C communication. What is going on?
TIQ
There can be a sync problem, avoid using this function:
CurieIMU.readMotionSensor(aix, aiy, aiz, gix, giy, giz);
It will grab the data from the FIFO buffer for both Gyro and Accelerometer at the same time.
The problem with this is that the acquisition rates for gyro and accelerometer may be different
so this will cause problems.
Use these functions instead:
CurieIMUClass::readGyro(int &x, int &y, int &z)
and
CurieIMUClass::readAccelerometer(int &x, int &y, int &z)
Make sure you use the following functions before data acquisition:
CurieIMU.dataReady(GYRO) : this will return true if the gyro is enabled and has new data ready.
CurieIMU.dataReady(ACCEL) : this will return true if the accelerometer is enabled and has new data ready.
TIQ
and
