I got an arduino 101 and are trying to use an AM2315 on it.
But I dont get any data.
It looks like the i2c speed is wrong? Have anyone got the AM2315 to work on the Intel Curie chip?
Here is my test code.
# include
# define AM2315_I2CADDR 0x5C
# define AM2315_READREG 0x03
uint8_t reply[10];
void setup() {
Serial.begin(9600);
Wire.begin();
void loop() {
// Wake up the sensor
Wire.beginTransmission(AM2315_I2CADDR);
delay(2);
Wire.endTransmission();
// OK lets ready!
Wire.write(AM2315_READREG);
Wire.write(0x00); // start at address 0x0
Wire.write(4); // request 4 bytes data
delay(10); // add delay between request and actual read!
Wire.requestFrom(AM2315_I2CADDR, 8);
for (uint8_t i=0; i<8; i++) {<p> reply[i] = Wire.read();
Serial.println(reply[i], HEX);
delay(2000);
The code Works fine on the Arduino Mega 2560.
Tryed using "Wire.setClock(400000L);" but did not help
Hi KimLorentz,
Thank you for contacting us.
Unfortunately, we don't have the device you're using with the Arduino 101 so we can't test this ourselves.
Please consider that the Arduino 101 is supported by Arduino.cc, we recommend you to contact them here: https://www.arduino.cc/en/Main/ContactUs https://www.arduino.cc/en/Main/ContactUs . They will be able to provide a more accurate response to your question.
-Sergio A
