Intel® Makers
9874 Discussions
Intel DnX Driver Doesn't work
AuliaF
Black Belt
I'm following this tutorial https://software.intel.com/en-us/flashing-the-bios-on-joule IoT - Flashing the BIOS | Intel® Software but Intel DnX driver doesn't work, any help?
Brendan_L_Intel
Have you booted correctly in DNX mode by holding the DNX boot button? In case you haven't already reboot your PC, unplug the Joule and make sure it's powered by a suitable 2A+ 12V powersupply.
AuliaF
Black Belt
Yes, already powered with external power and holding DNX boot button, still recognized as other devices
Brendan_L_Intel
It might be worth trying USB2 ports (if you're using USB3 ports or vice versa) or another windows box if you have access to one just to rule that out.
AuliaF
Black Belt
try on other PC and same result
AuliaF
Black Belt
try manually install FlashUsbDriver-1.0.0.exe under the folder Joule_BIOS_2016-08-11-A16\BIOS_A16\DNX-dldrcli\installer\
It's Working now, I don't know either this is the real solution for this problem or not, but after installing and restart, my Joule work,
and all the instruction on documentation also working,
now try programming using Intel XDK
Community Manager
I don't seem to be able to get the DnX driver to install under device manager.
I tried this:
No joy
Community Manager
OK so now when i plug in the dev board, device manager sees the Intel DnX Device. But when I run the flash.bat script i get "access denied". Unlike the pics in the manual I only have the one LED on the right hand side of the board lit up. The four LED's above the 50 pin header are not lit up. Only the flash connection is plugged in.
AuliaF
Black Belt
1. Connect usb type c to joule (but dont connect yet to host/laptop)
2. Press dnx boot button (hold until step 4)
3. Insert power supply 12V 2A
4. Insert usb type c to host/laptop
5. Run flash.bat
Community Manager
faqsun:
i tried doing it in your order. Still no joy. The 4 lights above the header never come on. Plus the manual never talks about or shows connecting the power. After step 3 should I wait until the 4 lights come on (they don't even holding down the button for quite a while.)
AuliaF
Black Belt
You can try connecting monitor to micro HDMI port to show what exactly running by Joule,
Or try open putty, serial connection, set the COM, set 115200 baud, keep putty open
In my experience :
1. Joule with no external power supply will cause device keep restarting
2. 4 led lights on is normal state (OS is running)
3. 1 led light on is dnx boot state
