Community
cancel
Showing results for
Search instead for
Did you mean:
HC_R
Intel Edison - 300mA current when PWM is enabled -
I enabled PWM channel 3 of Intel Edison for a frequency of 10Khz and duty cycle of 50%. The Edison was powered from a DC source of 3.7V.
After enabling the PWM current consumption went to 300mA from 60mA. Why the PWM module is taking too much current ? is this expected behavior ?
echo mode1 > /sys/kernel/debug/gpio_debug/gpio183/current_pinmux
echo 3 > /sys/class/pwm/pwmchip0/export
echo 50000 > /sys/class/pwm/pwmchip0/pwm3/duty_cycle
echo 100000 > /sys/class/pwm/pwmchip0/pwm3/period
echo 1 > /sys/class/pwm/pwmchip0/pwm3/enable
Hp,
Community Manager
Hi Hari_CR,
I'd say that it's normal to have that increase in the current consumption, however let me investigate more about it to confirm whether it's normal or not.
I'll post an update as soon as possible.
Diego
HC_R
Sorry for the inconvenience,
I had a schottkey diode placed turned around which was taking this much current, deploying it properly solved the issue.
Community Manager
Hi Hari_CR,
Don't worry, it's great that you found the root of the issue.
Diego
