I am trying to design a case for my Intel Edison to house a small electronics project. I can see in the Arduino Board Hardware Guide (http://download.intel.com/support/edison/sb/edisonarduino_hg_331191007.pdf here) that the PDF references a file called "H40482-004_edison_arduino_HVM_dim.dxf" and lists some measurements, but the text is too blurry and low-resolution to read. I can't seem to find that file anywhere. Is that file available somewhere, or could it be made available somewhere, so that I and others in the future can use it directly in Autodesk software to design accessories for the Edison Arduino board?
Hi briman0094,
You can find the .dxf file of the Edison module in the following site, under section "Drawings": https://www-ssl.intel.com/content/www/us/en/do-it-yourself/support/maker/edison/edison-documents-and... Intel® Edison Boards Hardware Support
On the other hand, there are also files of the expansion boards, but they can only be opened by Allegro. You can find these files on the same site, under sections "Intel Edison Breakout Board" and "Intel Edison Arduino Board".
If the information that you are looking for is not on that site, I'm afraid that it's not available.
Diego
Hi briman0094,
Diego
