I'm in the "Getting Started" setup phase for Edison, running the Intel_Edison_Setup_Lin_2016.2.002/install_GUI,sh script.
The script runs a config tool gui, which, after a few failed tries, manages to download the iot_data.xml file.
After getting through that hurdle, the following error is given:
Unsupported OS
Detected operating system is not supported. Supported operating systems for this release are:
- Ubuntu* 12.04 (Intel(R) 64), 13.04 (Intel(R) 64), 14.04 (Intel(R) 64), 15.04 (Intel(R) 64)
I'm using "xenial" Ubuntu 16.04.2 LTS . Why is the Edison installation tool only support old versions?
It would be OK if the installation were being done by a script, because I'd just fix it myself. However, the installation
uses compiled binaries.
Can you refer me to either the updated installation/config scripts/binaries, or at least the source code for them?
Did some googling... The answer is in:
