Community
cancel
Showing results for
Search instead for
Did you mean:
lyipi
Intel Edison Ecplipe C++ C11 support
In my project, I find the "__cplusplus" MACRO is 199711L.So I can not use new functions in C11. Any solution?
Tags (1)
Pedro_M_Intel
Hello shadox,
What are you trying to achieve? Why do you need C11?
Peter.
lyipi
Hi Peter,
I want to use the C11 standard multithread Library like "Thread","Mutex","Future". I know I could achieve those by using the Posix Threads.I just want to try doing this using the C++ standard Library as the version of gcc/g++ compiler in Edison in beyond 4.9,It should support C11.
Shadox.
Pedro_M_Intel
I understand, let me do some tests and a little bit of research and I'll get back to you.
Peter.
lyipi
Hi perter,
Here I am looking forward to your answer.
shadox
Pedro_M_Intel
I found in https://software.intel.com/en-us/eclipse-for-iot-troubleshooting-and-faq# How_to_set_C++11 Eclipse* for Intel® IoT Platforms Troubleshooting and FAQ how to set C++11 on Eclipse, have you tried the steps found there?
In case it doesn't work, could you share your code to see if we can replicate the issue?
Peter.
lyipi
I have tired(my OS is OS X EL Capitan),but did not help.This just set the compile flag while the preprocessor Macro "__cplusplus" is still 199711L.The Eclipse IDE just can not get the right code.
lyipi
Besides the steps in the FAQ. I add a preprocessor macro below, which solve the problem ╮(╯▽╰)╭
