Community
cancel
Showing results for
Search instead for
Did you mean:
MStok
Intel Edison/Galileo MQTT Client
Hi There
So I am currently trying to get an MQTT client up and running to run TCP/IP, SSL and TLS-PSK with mosquitto on an intel galileo gen 2 board. I have been following this tutorial (https://www.codeproject.com/Articles/993790/Using-Edison-Securely-connect-IoT-Sensor-to-the-In https://www.codeproject.com/Articles/993790/Using-Edison-Securely-connect-IoT-Sensor-to-the-In) administered by Intel. What I am unsure about is how to implement the configuration directives as shown in the attached picture. Must I create a new .conf file or edit an existing one? Or has it got nothing to do with configuration files? Just not sure what to do or how to implement them. Any help on the subject would be appreciated.
Thanks,Matthew
Tags (1)
Shah_Intel
Thank you for contacting Intel Premier Support.
We have received your request and shortly we will be contacting you with additional information.
Under contract to Intel
Shah_Intel
Dear Customer,
Have you try to check the mosquitto.conf example at"/etc/mosquitto/mosquitto.conf.example"?
Do you able to find the configuration file?
In the configuration file explain in detail.
