Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Intel Edison + Grove Starter Kit Plus using C
Jump to solution
Is it possibile to read from sensors from Grove Starter Kit Plus connected to Intel Edison using C? Every tutorial talks about C++, Arduino or JS.
Community Manager
HelloPawek,
Yes, indeed you can interact with those sensors using C. The only detail that you might encounter is, as you mention, that you might not find examples for them. However, if they are based on SPI, I2C, UART, etc, then you should be able to use mraa to interact with them. I'd suggest you to check mraa's C examples. You can find them in https://github.com/intel-iot-devkit/mraa/tree/master/examples.
-Peter.
Community Manager
HelloPawek,
-Peter.
Community Manager
Thank you. I figured out earlier how to do this! Anyway I appreciate your support.
