Intel® Makers
9880 Discussions
Intel Edison Libraries
ZArsh
I am fairly new with the Intel Edison, i have gone though the setup and have successfully uploaded the blink command example to the Edison ( with a breakout board). But when i try to print anything to the serial monitor, nothing appears and i receive the following messages when ever i use any code. Please provide assistance and be detailed. Again, im fairly new to the Intel Edison.
Warning: platform.txt from core 'Arduino i686 Boards' contains deprecated recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} "{build.path}/{archive_file}" "{object_file}", automatically converted to recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} "{archive_file_path}" "{object_file}". Consider upgrading this core.
Board Intel:i686:izmir_ec doesn't define a 'build.board' preference. Auto-set to: I686_IZMIR_EC
WARNING: Category '' in library DallasTemperature is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library EEPROM is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library Ethernet is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library EthernetShield is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library OneWire is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library SD is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library SPI is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library Servo is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library SoftwareServo is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library TimerOne is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library USBHost is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library WiFi is not valid. Setting to 'Uncategorized'
AND
Invalid library found in C:\Users\Zohaib Arshad\AppData\Local\Arduino15\packages\Intel\hardware\i686\1.6.2+1.0\libraries\Wire: C:\Users\Zohaib Arshad\AppData\Local\Arduino15\packages\Intel\hardware\i686\1.6.2+1.0\libraries\Wire
I checked the library folder and i do have the following: Bridge, Esplora, Ethernet, Firmata, GSM, Keyboard, LiquidCrystal, Mouse, Robot_Control, Robot_Motor, RobolRremote, SD, Servo, SpacebrewYun, TFT, WiFi, Readme.
Thank you.
Joseph_B_Intel
ZohaibArshad, it should work fine in 1.6.6. Came across that same error today, what you need to do is rename the file /.arduino15/packages/Intel/hardware/i686/1.6.2+1.0/libraries/Wire/libraries.properties to library.properties
Here is the original thread that led me to that https://forum.arduino.cc/index.php?topic=362521.0 https://forum.arduino.cc/index.php?topic=362521.0
Hope this helps!
Diego_V_Intel
Hello ZohaibArshad,
I've seen those messages in the Arduino IDE 1.6.6. I'm not sure if your are using that version, but I would recommend to use the Arduino IDE 1.6.0. This is the most stable version to work with Edison and Galileo boards. You can download it from the following site: http://downloadmirror.intel.com/24783/eng/IntelArduino-1.6.0-Windows.7z http://downloadmirror.intel.com/24783/eng/IntelArduino-1.6.0-Windows.7z
Diego.
Joseph_B_Intel
Hope this helps!
