Community
cancel
Showing results for
Search instead for
Did you mean:
NMusz
Intel Edison Not Flashing Correctly
Jump to solution
I have been trying to flash my Intel Edison with both flashall.sh and flash tool lite. It does not mount on any computer and I cannot connect via serial with putty. When I try to flash it, I either get:
Device has DFU interface but no DFU functional descriptor  Cannot open DFU device 8087:0a99
or:
12/14/18 06:47:39.220 INFO : [Port 1/3/2] XFSTK-STATUS--Error Code: 0 - Success 12/14/18 06:47:39.220 INFO : [Port 1/3/2] XFSTK-STATUS--Firmware and OS download completed. 12/14/18 06:47:39.220 INFO : [Port 1/3/2] XFSTK: Transfer Completed Successfully. 12/14/18 06:47:39.220 INFO : [Port 1/3/2] Success: Download of FW Completed. 12/14/18 06:47:39.220 INFO : [Port 1/3/2] xfstkFlashTool exited with success 12/14/18 06:47:39.220 INFO : [Port 1/3/2] Command `"C:\Program Files (x86)\Intel\Platform Flash Tool Lite\xfstkFlashTool.exe" "-1" "D:\Downloads\edison-image-ww25.5-15\edison_dnx_fwr.bin" "D:\Downloads\edison-image-ww25.5-15\edison_ifwi-dbg-00.bin" "D:\Downloads\edison-image-ww25.5-15\edison_dnx_osr.bin" "D:\Downloads\edison-image-ww25.5-15\u-boot-edison.img" "0x80000007" "none" "none" "0"` succeed 12/14/18 06:47:39.220 INFO : [Port 1/3/2] Running `Wait for device with status pos on port 1/3/2` command 12/14/18 06:47:52.794 INFO : [Port 1/3/2] Command `Wait for device with status pos on port 1/3/2` succeed 12/14/18 06:47:52.794 INFO : [Port 1/3/2] Running `"C:\Program Files (x86)\Intel\Platform Flash Tool Lite\dfu-util.exe" "--alt" "u-boot0" "-D" "D:\Downloads\edison-image-ww25.5-15\u-boot-edison.bin" "-t" "4096" "-d" "8087:0a99" "--path" "2-3.2"` command 12/14/18 06:47:52.920 WARNING: [Port 1/3/2] Command `"C:\Program Files (x86)\Intel\Platform Flash Tool Lite\dfu-util.exe" "--alt" "u-boot0" "-D" "D:\Downloads\edison-image-ww25.5-15\u-boot-edison.bin" "-t" "4096" "-d" "8087:0a99" "--path" "2-3.2"` failed 12/14/18 06:47:52.920 INFO : [Port 1/3/2] Retrying `"C:\Program Files (x86)\Intel\Platform Flash Tool Lite\dfu-util.exe" "--alt" "u-boot0" "-D" "D:\Downloads\edison-image-ww25.5-15\u-boot-edison.bin" "-t" "4096" "-d" "8087:0a99" "--path" "2-3.2"` command 12/14/18 06:47:52.950 ERROR : [Port 1/3/2] Command `"C:\Program Files (x86)\Intel\Platform Flash Tool Lite\dfu-util.exe" "--alt" "u-boot0" "-D" "D:\Downloads\edison-image-ww25.5-15\u-boot-edison.bin" "-t" "4096" "-d" "8087:0a99" "--path" "2-3.2"` failed 12/14/18 06:47:52.950 ERROR : [Port 1/3/2] Flash failed (Command type: DFU)
I have it connected with cables that have worked in the past with the board, and it is connected to an external supply.
FerryT
Valued Contributor I
Do you mean you are running flashall.sh from linux and Flash Tool Lite from Windows? I don't know with windows, but AFAIK you need to install the drivers (as is normal on windows).
On linux I found I need to use `sudo flashall`, otherwise I get exactly your 1st error message.
FerryT
