Intel® Makers
9882 Discussions
Intel Edison Part Numbers?
NHump1
I'm trying to buy more Intel Edisons in a bulk fashion
On mouser I see the following versions
Intel:
EDI2.SPOF.AL.S
EDI2.LPON.AL.S
EDI2.LPOF.AL.S
EDI2.SPON.AL.S
EDI2.SPON.AL.MP
EDI2.LPON.AL.MP
EDI2.LPOF.AL.MP
EDI2.SPOF.AL.MP
I originally got mine with the breakout board so I am not exactly sure which it is.
I would like to know if there is any noticeable difference in there different versions.
I don't see any documentation related to what these could even be.
I believe there is an edison 2 and edison 1 and need to make sure I get the edison 2. Is that true? could there be any possible difference in the edison 2's?
if it is just firmware differences on preload then I don't care.
Link to mouser
http://www.mouser.com/Search/Refine.aspx?Keyword=intel+edison http://www.mouser.com/Search/Refine.aspx?Keyword=intel+edison
Carlos_M_Intel
Hi IntelEddiPci,
You can find the Intel Edison Platform in different versions:
Intel Edison Compute Module
Intel Edison Compute Module + Breakout Board
Intel Edison Compute Module + Arduino Expansion Board
Mouser has different models, the ones you mentioned above are related with the Intel Edison Compute Module, you can see in all the options you posted the same specifications and prices.
There are not an Edison 1 and Edison 2. There is only one Edison, Mouser has these models in order to have different and more certificates to sale the products to different countries.
If you want to buy the units from Mouser I suggest youhttp://www.mouser.com/contact/ to contact them for more information about the models the y offer and which is the best option for you.
You can also send an email using this form http://www.intel.com/support/mailform/maker/edisonsupport.htm Intel Support to check if there is another option for purchase a high volume of units.
Kind regards,
Charlie
Carlos_M_Intel
Hi IntelEddiPci,
Kind regards,
Charlie
NHump1
So just to clarify there is not a version of the Intel Edison that only has the u.FL connector as a test point?
There seems to be a lot of buzz online that some editions can use the u.FL with an external connector and others don't use it and are just a test point.
If I just attach an antenna to the u.FL connector on any Edison then I will be using that antenna as my Wifi Antenna?
Carlos_M_Intel
Hi IntelEddiPci,
Yes, there is one. You can purchase a version with an u.FL connector working as a test point or for an external antenna.
Take a look at the http://download.intel.com/support/edison/sb/edisonmodule_hg_331189004.pdf Hardware Guide for the Compute Module (Section 3.7)
Note: The internal antenna versions also have a u.FL connector on the board, but it is only used as
a manufacturing test point. Do not connect an external antenna to a board with an internal antenna
Charlie
VIvan7
New Contributor III
Can you unsolder the ceramic antenna or a resistor near it if you use an external antenna?
For me it works just fine with an external antenna. But if I unsolder the ceramic antenna, I can use the space below it for components.
Carlos_M_Intel
Hi Vincenze,
I do not suggest you to remove anything from the Expansion Boards nor from the Compute Module. This could permanently damage the board.
Charlie
