Intel® Makers
9881 Discussions
Intel Edison - Ports in Device Manager
CGuid
I have two Edison Boards and I can't effectively communicate with either. When plugging one into my computer and opening the device manager and navigating to ports the USB serial port (com# ) comes up but nothing else does. When I use the other Edison with the same computer the virtual com port and usb composite device options come up, but no serial port. How is this possible. I have manually installed all the necessary drivers and been able to successfully flash both boards. I can't get either board to work through putty (no surprise for the board without a working serial connection). Any help would be appreciated.
Community Manager
Hello Charlie,
Thank you for contacting Intel Technical Support.
Please follow this article in order to troubleshoot this issue: https://www.intel.com/content/www/us/en/support/articles/000008491/boards-and-kits/intel-edison-boar...
Also we would suggest you to reflash the board using the following steps: https://software.intel.com/en-us/flashing-firmware-on-your-intel-edison-board-windows
Octavian
