Community
cancel
Showing results for
Search instead for
Did you mean:
EAkto
Intel Edison Send Spi Datas Between Delay Problem
I send Spi data in loop on the Intel Edison and I looked data.I saw delay in the between datas.Delay is 300 us.Delay is too long.How can I solve this?I use Intel Xdk Iot Ide.
Sergio_A_Intel
Please provide more information on your testing scenarios. What code are you using, did you make your own code or are you using a sample code? How are you sending and looking at the data, what commands are you using to send data, do you have a logic analyzer to test the signals? With which command are you setting the delay to 300us. What happens if you shorten the delay in your code?
Sergio
Carlos_M_Intel
Hi ErayAktokluk,
Could you provide more information about the behavior you are having in your project?
Have you been able to solve this?
Charlie
