Community
cancel
Showing results for
Search instead for
Did you mean:
EAkto
Intel Edison Use Gpio Without Mraa Library
Jump to solution
Hi,I want to use Intel Edison's gpio without mraa.I think I should use linux's commands but I dont know How can I do that.Thank you for your answer.
Community Manager
Hi Eray,
MRAA is the easiest and possibly the best way to use the GPIO pins, but if you're really interested in using the GPIO pins from Linux you can check this http://www.i-programmer.info/programming/hardware/9618-exploring-edison-beyond-mraa-.html http://www.i-programmer.info/programming/hardware/9618-exploring-edison-beyond-mraa-.html. This is a very complete guide on how to use the GPIO pins without MRAA. Check their other material on the Edison, they have some good tutorials.
-Pablo
RRobe17
I am not sure why you would want to do this. However, who am I to question. I can and have controlled GPO pins on Raspberry Pi's without any additional libraries, as a matter of fact it can be done from the command line.
I have to suspect that the Edison does the same thing. Please have a look at this information.
https://gist.github.com/ChickenProp/3050085 Simple Raspberry Pi GPIO example · GitHub
http://www.raspberry-projects.com/pi/command-line/io-pins-command-line/io-pin-control-from-the-comma... IO pin control from the command line – Raspberry Pi Projects
Again, I have not tried this yet on my Edison, simply because the work involved is too much IMHO and it is easier to use a library.
EAkto
Thank you for your answer.It is helpful.
Community Manager
Hi Eray,
-Pablo
Community Manager
Hi Eray,
Do you still need help with this case? Did you find the information useful?
-Pablo
