Intel® Makers
9881 Discussions
Intel Edison board interfacing with 2.4 inch LCD TFT Screen
RKuma42
I procured the LCD TFT 2.4 inch. as like present on this link.http://www.rhydolabz.com/displays-c-88/24-inch-tft-lcd-touch-screen-module-for-arduino-p-1794.html 2.4 Inch TFT LCD Touch Screen Module For Arduino .
I have Interfaced this LCD with Arduino UNO .It works well...By Including several TFT Adafruit_GFX library.
when I am interfacing with Intel Edison Breakout board with Arduino IDE with TFT 2.4 inch LCD breakout board.
I am not able to interface it.they are asking me to include Extra libaraary such as "avr/io".after including it also the program is not working.
Now can anyone tell me what kind of Library to be included in order to work with Intel Edison breakout board with LCD TFT screen.
IF anyone worked On it Please tell me what and all extra library to be included for their working.
thanks
Community Manager
Hi rahul147258 ,
The error you are getting is because the library is not supported by Edison. It works on Arduino UNO because the library is based on the AVR architecture. Since Edison has a different architecture you are getting that error and the library won't work.
I'm not sure if it's the same TFT display as yours, but in the following threads, other users have been able to use TFT displays with Edison and the library you are using has been modified to work with Edison. I haven't test them by myself, but I recommend you to check those threads. You might find them useful.I think that the last thread discusses the same error you are getting. The user was able to use the display after a couple of modifications, however he used a Galileo board, but you could give it a try with Edison as well.
Diego
RKuma42
hi, Diego
Have gone through all this procedure and I faced several issues..
I wanted to interface 2.4 inch TFT LCD which seems like it has controller SPfd5408.. with Intel edison breakout board.
Now i have gone to the library which ur provided for the" ILI9341 https://github.com/KurtE/Adafruit_ILI9341/tree/Intel-Edison ".
1) can u tell me whether this libraray suports for My 2.4 inch TFT LCD? because when i uploaded the graphics test program from this libaray it get compile.and There were no Error in Console Window..But output din come On LCD...
2)can u tell me how to change the IL9341 lIbaray details for making it to work with spfd5408 TFT LCD??
3)can u tell me any alternative way to handle this issue?
4) i have downloaded the Spfd5408 controller Libraray from https://github.com/JoaoLopesF/SPFD5408 GitHub - JoaoLopesF/SPFD5408: Adafruit Libraries changed to works in TFT 2.4 shields with the SPFD5408 controller for Ar… .
5) now i am not able to proceed farher.For UR information I have tested this LCD with arduino its working fine i just downaloded GFX and TFT libraray foo arduino it was working welll...
Please make it for edison..
5) please help me i am keen to learn about thses things...
your Obidient RAHUL
THANKS
Community Manager
Hi Rahul,
As we mentioned before, the TFT display hasn't been tested by us, and the library mentioned in the thread previously pointed was modified by another user who was able to setup the display. If you are using a different TFT screen or driver, then you would have to make the proper changes to the library or code to make it work. An option would be to contact the author of the modified library through Github since he was the one who did the proper changes to make it work.
-Pablo
Community Manager
Well, I have had some experience converting existing display libraries to work under Intel Edison. Worked on two different ones:
You have absolutely no choice but to convert existing libraries. These libraries are usually already configured to run under Arduino, and you must convert them to run under the Intel Edison. It's not an easy task, but it can be done. Allow me to present you some examples of how I converted their source code from Arduino to let them run on the Intel Edison.
First, here's an extract of the Github source code for the two displays I mentioned above.
From Sumotoy's RA8875 Github, we have:
void RA8875::_writeData(uint8_t data)
_startSend(); // delete this section - not relevant to Intel Edison
# if defined(___DUESTUFF) && defined(SPI_DUE_MODE_EXTENDED) // delete this section
SPI.transfer(_cs, RA8875_DATAWRITE, SPI_CONTINUE);
SPI.transfer(_cs, data, SPI_LAST);
# else
# if defined(__AVR__) && defined(_FASTSSPORT) // delete this section
_spiwrite(RA8875_DATAWRITE);
_spiwrite(data);
# else
# if defined(SPI_HAS_TRANSACTION) && defined(__MKL26Z64__) // delete this section
if (_altSPI){
SPI1.transfer(RA8875_DATAWRITE);
SPI1.transfer(data);
} else {
SPI.transfer(RA8875_DATAWRITE);
SPI.transfer(data);
# else
SPI.transfer(RA8875_DATAWRITE); // preserve this for Intel Edison
SPI.transfer(data); // preserve this for Intel Edison
# endif
# endif
# endif
_endSend(); // delete this section - not relevant to Intel Edison
From wallacezq's Github for the Adafruit display, we have:
uint8_t Adafruit_ILI9341::readdata(void) {
digitalWrite(_dc, HIGH); // preserve this for Intel Edison
digitalWrite(_cs, LOW); // preserve this for Intel Edison
uint8_t r = spiread(); // preserve this for Intel Edison
digitalWrite(_cs, HIGH); // preserve this for Intel Edison
return r; // preserve this for Intel Edison
uint8_t Adafruit_ILI9341::spiread(void) {
uint8_t r = 0; // preserve this for Intel Edison
if (hwSPI) { // only using hardware SPI, so will delete the else portion
# if defined (__AVR__) // delete this section
uint8_t backupSPCR = SPCR;
SPCR = mySPCR;
SPDR = 0x00;
while(!(SPSR & _BV(SPIF)));
r = SPDR;
SPCR = backupSPCR;
# elif defined (__arm__) // delete this section
SPI.setClockDivider(11); // 8-ish MHz (full! speed!)
SPI.setBitOrder(MSBFIRST);
SPI.setDataMode(SPI_MODE0);
r = SPI.transfer(0x00);
# elif defined (__X86__)
r = SPI.transfer(0x00); // preserve this for Intel Edison
# endif
} else { // delete this section
for (uint8_t i=0; i<8; i++) {
digitalWrite(_sclk, LOW);
digitalWrite(_sclk, HIGH);
r <<= 1;
if (digitalRead(_miso))
r |= 0x1;
//Serial.print("read: 0x"); Serial.print(r, HEX);
Here are the corresponding changes I made to enable the RA8875 and ILI9341 on the Intel Edison. You should notice a pattern:
digitalWrite(_cs, LOW); // there ought to be some chip select to turn on the display
SPI.transfer(RA8875_DATAWRITE); // next send out the command
SPI.transfer(data); // followed by sending out the data
digitalWrite(_cs, HIGH); // turn off the chip select
digitalWrite(_dc, HIGH); // select data instead of command for the D/CX pin
uint8_t r = spiread(); // read in the data
return r;
uint8_t r = 0;
r = SPI.transfer(0x00); // read in the data from 0x00
return r; // return the data that is read in
Notice how I deleted chunks of conditional compilation code that was not relevant to the Intel Edison (eg, _DUESTUFF, SPI_HAS_TRANSACTION, __AVR__, and __arm__).
If your hardware provider support is excellent, you can usually use the library as provided (no changes required). However, sometimes the library could benefit from tidying up as you add more even more of your own functionally; in that case, keep parts of code that are Intel Edison compatible, (eg, __X86__), and delete everything else that is irrelevant. Of course, you may say there's no benefit to tidying code that way, but it's entirely up to you.
When the classes are constructed, you also need to determine the initialization method, for example, whether _CS (chip select) is required, _CLK (clock), etc. Check the hardware specifications, for example, I looked up the http://http//www.buydisplay.com/download/ic/RA8875.pdf RA8875 and <a href="http://https//cdn-s...
RKuma42
Thanks for help,
see now I think the LCD which I a m using is having spdf5048 controller and the LCD does not have SPI communication. what are Modification must be done for interfacing with Intel Edison.
I have downloaded the library from this Link can u tell me wat modification must be one.
now please guide me what changes must be Done??
thanks for helping ..I understood ur code but that will work on SPI communication. Right now my requirement is this 2.4 TFT LCD
Community Manager
I think the problem is found in pin_magic.h.
There are conditional compiles aplenty in there that is hardware specific to the Arduino Board and its variants. You need to find a set of code that works for the Intel Edison, otherwise you have to refer to the hardware specs of the display chip and rewrite that file.
Examples:
Line 67 -
# if defined(__AVR_ATmega168__) || defined(__AVR_ATmega328P__) || defined (__AVR_ATmega328__) || defined(__AVR_ATmega8__)
Line 134 -
# elif defined(__AVR_ATmega1281__) || defined(__AVR_ATmega2561__) || defined(__AVR_ATmega2560__) || defined(__AVR_ATmega1280__)
Line 165 - I believe your code is compiling to this section of code... look through to see why it is not working? Are changes required? Do you have to use another # if section?
# else // Mega w/Breakout board
Line 71 - Will this section of code be necessary? You decide.
# ifdef USE_ADAFRUIT_SHIELD_PINOUT
Community Manager
Also, be cognizant of the Intel Edison core code. For me, it's installed over at:
[USERS]\AppData\Local\Arduino15\packages\Intel\hardware\i686\1.6.7+1.0\cores\arduino
[USERS]\AppData\Local\Arduino15\packages\Intel\hardware\i686\1.6.7+1.0\variants
Files like pins_arduino.h and wiring_digital.h in these folders must be included and will need to match up with whatever has been coded for the spdf5048 (arduino version). You will need to translate them so that the right pin and calling method is used.
So, if you keep getting compilation errors, look inside all of these files.
I won't be able to help you much since I don't have this display card in my inventory.
Good luck!
Community Manager
Another thing.
Looking at this diagram tells me that quite a number of pins would be used. Please also check the Intel Edison hardware specs document (at http://download.intel.com/support/edison/sb/edisonarduino_hg_331191007.pdf http://download.intel.com/support/edison/sb/edisonarduino_hg_331191007.pdf ) to ascertain the pins are configured correctly.
RKuma42
Thanks for replying
when I interfaced this with arduino I have to utilize all the pins from arduino except pin number A5.so I tried to interface same with Intel Edison board arduino expansion board.
from this Diagram I have to utilize all the pIns.
thanks
