Hi everyone.
I just bought an Intel Eedison. I've been through all start stuffs, and now I would like to install Ubilinux on it.
I can see the board on 'My Computer' and I can talk to the board with PuTTY. In on Windows 7. I already downloaded the dfu-util.
When I try to run the flashall.bat in the script tell me to plug the board, I do so but the program exit with 'Dfu device not found Timeout'.
Does anyone know what can cause that ?
In the mean time I would like to now if it's normal that when I plug the board it connects and disconnects 2 times and then connects for good ?
Thank you for your help ?
If you are looking for help with the Ubilinux Image I'd suggest you to go to http://www.emutexlabs.com/forum/index EmutexLabs . Here you'll find support for the Ubilinux image and find a more accurate response to your issue.
Sergio
Sergio
I will do that thanks for your advise.
Any idea why does my board connect and disconnect 2 times before be ready ?
Sometimes this is related to the power supply. If you are using two USB cables to power the board try using an external power supply connected to J1.
Sergio
