Hi folks,
my Intel Edison stopped being reachable by terminal and ssh over wifi, so I decided to flash it.
$ ./flashall.sh
Using U-Boot target: edison-blankcdc
Now waiting for dfu device 8087:0a99
Please plug and reboot the board
Timed out while waiting for dfu device 8087:0a99
DEBUG: lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 138a:0090 Validity Sensors, Inc.
Bus 001 Device 003: ID 04f2:b52c Chicony Electronics Co., Ltd
Bus 001 Device 005: ID 8087:0a2b Intel Corp.
Bus 001 Device 057: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
DEBUG: dfu-util -l
dfu-util 0.9
Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2016 Tormod Volden and Stefan Schmidt
This program is Free Software and has ABSOLUTELY NO WARRANTY
Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
Did you plug and reboot your board?
If yes, please try a recovery by calling this script with the --recovery option
The normal flashing did not work, so I tried the recovery option:
$ ./flashall.sh --recovery
Starting Recovery mode
Flashing IFWI
XFSTK Downloader Solo 1.8.1-5.1
Copyright (c) 2015 Intel Corporation
Build date and time: Sep 1 2017 15:13:00
Intel SoC Device Detection Failed: Attempt # 0
Intel SoC Device Detection Failed: Attempt # 1
Intel SoC Device Detection Failed: Attempt # 2
Intel SoC Device Detection Failed: Attempt # 3
Intel SoC Device Detection Failed: Attempt # 4
Intel SoC Device Detection Failed: Attempt # 5
Intel SoC Device Detection Failed: Attempt # 6
Intel SoC Device Detection Failed: Attempt # 7
Intel SoC Device Detection Failed: Attempt # 8
Intel SoC Device Detection Failed: Attempt # 9
Intel SoC Device Detection Failed: Attempt # 10
Intel SoC Device Detection Failed: Attempt # 11
Intel SoC Device Detection Failed: Attempt # 12
Intel SoC Device Detection Failed: Attempt # 13
Intel SoC Device Detection Failed: Attempt # 14
Intel SoC Device Detection Failed: Attempt # 15
Intel SoC Device Detection Failed: Attempt # 16
Intel SoC Device Detection Failed: Attempt # 17
Intel SoC Device Detection Failed: Attempt # 18
Intel SoC Device Detection Failed: Attempt # 19
Intel SoC Device Detection Failed: Attempt # 20
Xfstk tool error
DEBUG: lsusb
DEBUG: dfu-util -l
dfu-util 0.9
So there was no success either. I figured I should try a serial connect:
$sudo screen /dev/ttyUSB0
4DE���}��D��E����u�5�d��ZR��Z��~���g�����gZ�cWs�gK�f�s��SgR�s�~�os{k����K
So there is something coming from the Edison upon reboot... Every time I reset the Edison, this line of garbage is being received again...
Does anybody have any clue how to proceed with this?
Thank you!
Hi Christian,
Thanks for your interest in the Intel Edison Kits.
Could you please tell us if you followed the steps from the link below? : https://www.intel.com/content/www/us/en/support/articles/000006285/boards-and-kits.html
You can also try using FlashToolLite in order to flash the latest Firmware on Intel Edison Board: https://01.org/node/2463
Please let us know if you have additional questions.
George
Hi Christian,
George
Yes, I followed these steps and it already fails at step 2.
If I connect both cables to my computer and invoke screen, I get a reboot loop. I guess it is due to insufficient power from the USB port:
$ sudo screen /dev/ttyUSB0 115200
PSH KERNEL VERSION: b0182b2b
WR: 20104000
SCU IPC: 0x800000d0 0xfffce92c
PSH miaHOB version: TNG.B0.VVBD.0000000c
microkernel built 11:24:08 Feb 5 2015
******* PSH loader *******
PCM page cache size = 192 KB
Cache Constraint = 0 Pages
Arming IPC driver ..
Adding page store pool ..
PagestoreAddr(IMR Start Address) = 0x04899000
pageStoreSize(IMR Size) = 0x00080000
*** Ready to receive application ***
WR: 20104000
WR: 20104000
WR: 20104000
So I connected J16 to an external power supply and J3 to a USB port on my computer. Then I see the following:
WR: 20104000
U-Boot 2014.04 (Jun 06 2016 - 14:40:07)
Watchdog enabled
DRAM: 980.6 MiB
MMC: tangier_sdhci: 0
In: serial
Out: serial
Err: serial
Hit any key to stop autoboot: 0
Target:blank
Partitioning already done...
Flashing already done...
GADGET DRIVER: usb_dnl_dfu
reading vmlinuz
5461344 bytes read in 135 ms (38.6 MiB/s)
Valid Boot Flag
Setup Size = 0x00003c00
Magic signature found
Using boot protocol version 2.0c
Linux kernel version 3.10.98-poky-edison+ (neck@flax) # 1 SMP PREEMPT Mon Jun 6 14:32:08 PDT 2016
Building boot_params at 0x00090000
Loading bzImage at address 00100000 (5445984 bytes)
Kernel command line: "rootwait root=PARTUUID=012b3303-34ac-284d-99b4-34e03a2335f4 rootfstype=ext4 console=ttyMFD2 earlyprintk=ttyMFD2,keep loglevel=4 g_multi.ethernet_config=cdc systemd.unit=multi-user.target hardware_id=00 g_multi.iSerialNumber=a4015fb9e5c0de59334eaaf4e10feb92 g_multi.dev_addr=02:00:86:0f:eb:92 platform_mrfld_audio.audio_codec=dummy"
Starting kernel ...
So it just hangs when the kernel is supposed to be started...
Thanks for your help...
Hello Christian,
We would really appreciate if you could provide us the answers to the following questions:
When was the last time the board worked?
Were there any external sensors connected?
Any additional information that could help us to identify the problem would be much appreciated.
We also suggest that you submit a warranty request via web ticket.
George
Hello George,
thank you for your reply. The board stopped being reachable by ssh (over wifi) about 3 weeks ago. Then I realized the problems explained above. There were no external sensors connected, it was just performing calculations.
Strangely enough, I tried again and again and suddenly yesterday it booted up successfully. I have no explanation, but for the moment everything seems to be ok.
Thanks for your support.
Christian
Hello Christian,
Thank you for informing us. We are happy to hear that your problem is solved.
Please let us know if you have any other updates or questions.
Have a nice day.
George
