Intel® Makers
9882 Discussions
Intel Edison install opencv-dev error
Community Manager
Add the following lines to base-feeds.conf
src/gz all http://repo.opkg.net/edison/repo/all
src/gz edison http://repo.opkg.net/edison/repo/edison
src/gz core2-32 http://repo.opkg.net/edison/repo/core2-32
root@edison:~# opkg update
root@edison:~# opkg install opencv-dev
Collected errors:
* check_data_file_clashes: Package glibc-gconv wants to install file /usr/lib/gconv/gconv-modules
But that file is already provided by package * eglibc-gconv
* opkg_install_cmd: Cannot install package opencv-dev.
I use edison-image-ww18-15 。。
How do you solve the problem?
Community Manager
Hello bbqws60,
Thanks for reaching out!
May I ask why you are using the image ww18-05?
Using the latest image (201606081705) I simply used the command opkg install opencv-dev and after installing its dependencies (which are a lot), it installs the package correctly without any issue.
If there is no major reason why you need to use the image ww18-15, I suggest you to install the latest (which you can download from https://software.intel.com/en-us/iot/hardware/edison/downloads) image and try again.
If you must use the image ww18-15, please let me know and I'll install it on my Edison to see if I can replicate the issue and if so, try to see how to resolve it.
I hope this information helps you,
Pedro M.
Community Manager
Hello bbqws60,
Do you have any updates about this?
Pedro M.
