Community
cancel
Showing results for
Search instead for
Did you mean:
HC_R
Intel Edison - kernel recomiling for sleep mode patch
Hi
I was trying to patch the Intel edison kernel for the issue while trying to put edison into sleep for the second time as mentioned in this post
So followed the steps http://shawnhymel.com/724/creating-a-custom-linux-kernel-for-the-edison-yocto-2-1/ http://shawnhymel.com/724/creating-a-custom-linux-kernel-for-the-edison-yocto-2-1/
Downloaded the edison-sec-ww25.5-15.tgz andfollowed the steps upto bitbake virtual/kernel -c menuconfig
after that I edited the
edison-src/meta-intel-edison/meta-intel-edison-bsp/recipes-kernel/linux/files/upstream_to_edison.patch
so that the edit is incorporated in this patch and this will be applied while recompiling kernel
then did
bitbake virtual/kernel -c clean
bitbake virtual/kernel -c compile
bitbake -f deploy virtual/kernel
and
bitbake edison-image
after that I ran the ./flashall script to flash Edison, and when I tried echo -n "mem" > /sys/power/state two times it failed to put edison in sleep for the second time..
Am I missing some steps while recompiling the kernel ? (please pardon since I'm new to linux yocto compilation)
Community Manager
Hello Hari_CR,
Did you remember to replace the defconfig file after modifying menuconfig? You always need to replace this file for the one created by menuconfig, otherwise the changes will not take place. To learn more about menuconfig and how it works, I'd suggest you to read Yocto's Mega Manual (http://www.yoctoproject.org/docs/1.7.2/mega-manual/mega-manual.html http://www.yoctoproject.org/docs/1.7.2/mega-manual/mega-manual.html).
Also, did you try the suggestion made by @JimR in https://communities.intel.com/message/338169# 338169 https://communities.intel.com/message/338169# 338169?
Peter.
Community Manager
Hello Hari_CR,
Is there any update, have you been able to modify the image to enable sleep?
Peter.
HC_R
I went through the yocto manual
So this time I tried with a fresh copy of whole sdk/bsp (newly downloaded to enusre previous changes are not messing up)
I download the patch from https://github.com/01org/edison-linux/commit/149de7abd8829bcc009641e215b53fe89fcf29b2 pmu: stop powering up the pci device without driver · 01org/edison-linux@149de7a · GitHub
by
wget -O power.patch https://github.com/01org/edison-linux/commit/149de7abd8829bcc009641e215b53fe89fcf29b2.patch https://github.com/01org/edison-linux/commit/149de7abd8829bcc009641e215b53fe89fcf29b2.patch
Moved it into
edison-src/meta-intel-edison/meta-intel-edison-bsp/recipes-kernel/linux/files and updated the linux-yocto_3.10.bbappend by adding the line
SRC_URI += "file://power.patch"
Then did
cp tmp/work/edison-poky-linux/linux-yocto/3.10.17-r0/linux-edison-standard-build/.config ../../../meta-intel-edison/meta-intel-edison-bsp/recipes-kernel/linux/files/defconfig
cd ../../../meta-intel-edison/utils/flash/
./postBuild.sh ../../../out/linux64/build
cd ../../../out/linux64/build/toFlash/
./flashall.sh
After booting with the new image file the issue still seems to be there, ie; when I try echo -n "mem" > /sys/power/state for the second time Edison is not going to the sleep mode.
(Note: I verified that the file gets patched properly after compilation)
Am I missing something, please help me with your inputs ?
Community Manager
In this last build, which image were you using? Did you build it using the 2.1 BSP? Also, how did you verify that file was correctly patched? Have you tried to manually modify the file (instead of using the patch)? Is there any difference?
Peter.
HC_R
  • which image were you using?
- I'm using the edison-sec-ww25.5-15.tgz downloaded from Intel site and It downloaded yocto project with linux kernel 3.10.17-r0
  • Did you build it using the 2.1 BSP?
- I not sure about the version number of BSP, anyway I downloaded the latest tar/zip file from Edison forum
  • Also, how did you verify that file was correctly patched?
- Yes I checked the file after compilation whether the chnages in the patch is reflected in the actual files, and the actual files got patched.
  • Have you tried to manually modify the file (instead of using the patch)? Is there any difference?
- Earlier when I tried to edit file manually the changes were getting roll-backed after doing the bitbake edison-image, that's why I sticked with the patching method.
So what can cause the issue ? Is it possible to reproduce the same at your end, since our project is running out of date..
Also can you please suggest some place in the kernel file where I can put a printk() and ensure that is working.
Community Manager
Let me run some tests, I'm going to try to replicate the issue. I'll get back to you as soon as possible.
Peter.
HC_R
The link helped me solving issue.
Intel should consider seriously on changing the script, like, it should report error without superuser privilege (as of now it reports success even though its not flashed).
Community Manager
Hi Hari_CR,
Could you please share with us the steps you took to resolve the issue? It would be of much help for other users.
Peter.
HC_R
I just had to run the script in super user privilege ie; sudo ./flashall.sh,
Please update this script so that others wont repeat the mistake again , I think this can be added at the starting of script so that it reports error at the starting itself.
if [[ $EUID -ne 0 ]]; then
echo "This script must be run as root"
exit 1
fi
