Community
cancel
Showing results for
Search instead for
Did you mean:
VS121
Innovator
Intel Edison node.js sample code not working with grove 3-axis digital I2C accelerometer
Jump to solution
This is the sample code from Intel for running an accelerometer (Grove digital):
// Load accelerometer
var adxl345 = require('jsupm_adxl345');
// Instantiate on I2C bus
var adxl = new adxl345.Adxl345(0);
setInterval(function()
adxl.update(); // Update the data
var raw = adxl.getRawValues(); // Read raw sensor data
var force = adxl.getAcceleration(); // Read acceleration force (g)
var rawvalues = raw.getitem(0) + " " + raw.getitem(1) + " " + raw.getitem(2);
console.log("Raw Values: " + rawvalues);
console.log("ForceX: " + force.getitem(0).toFixed(2) + " g");
console.log("ForceY: " + force.getitem(1).toFixed(2) + " g");
console.log("ForceZ: " + force.getitem(2).toFixed(2) + " g");
}, 1000);
It builds and uploads to the Edison Arduino board, but when running it throws this error:
ERROR: /home/root/.node_app_slot/main.js:10
ERROR: var adxl = new adxl345.Adxl345(0);
ERROR: ^
ERROR: Error: UPM Runtime Error: Adxl345: i2c.write() control register failed
at Object. (/home/root/.node_app_slot/main.js:10:12)
at Module._compile (module.js:456:26)
at Object.Module._extensions..js (module.js:474:10)
at Module.load (module.js:356:32)
at Function.Module._load (module.js:312:12)
at Function.Module.runMain (module.js:497:10)
at startup (node.js:119:16)
at node.js:935:3
Any thoughts as to what's wrong there? The accelerometer is connected to an I2C port. Another sensor (temperature) is working ok.
VS121
Innovator
Problem solved! Indeed, it turns out there is another module for use with this accelerometer - it's MMA7660 so the upm package should be the mma one. I had a feeling that this must be the issue and Tudor confirmed it. I tried it and it worked!
Now do any good people on here have any thoughts of how to log the movement data on to a cloud and apply some analysis to it? trying to build an activity monitor... cheers!
Pedro_M_Intel
Hello VladWill,
I tried to run the same code but I'm seeing the same behavior as you. In this case I believe the best option is that you contact the creator of this script, you can find his contact information in https://github.com/intel-iot-devkit/upm/blob/master/examples/javascript/adxl345.js upm/adxl345.js at master · intel-iot-devkit/upm · GitHub, maybe he'd be able to provide you a more accurate answer.
Peter.
VS121
Innovator
Hi Peter
Thanks for looking into this as well. I actually did send him an email before posting here, but not heard anything back yet. If he has moved on from Intel, would there be no one else who looks after the sensors and could correct the code?? Maybe the adxl345 module is not even suitable for the grove digital accelerometer as it's a different maker...
VS121
Innovator
