Community
cancel
Showing results for
Search instead for
Did you mean:
AShar41
Intel Edison not working all of a sudden. Help!
I downloaded all the required drivers for the intel edison on my windows 7 for the USB and FTDI. DS1 led was constant and DS2 was blinking and I could see the edison drive on my system. I was installing the drivers manually because the automatic installer wasn't working for some reason. I downloaded the latest Yocto image and tried to flash it but it won't succeed. It kept failing at 38% with some DFU error.
After that I can't see the Edison drive on my system. And DS2 LED is not blinking at all. DS1 is blinking fine. And from what I have noticed, only one LED seems to light up out of DS1 and DS2 at a time. And in the Phone Flash suite, I can see that the device is connected but can't see the edison drive and it still wouldn't flash. I have the microswitch down and all cables in the correct configuration.
Any ideas what's happening?
Carlos_M_Intel
Hi Ank_IOT
What is the problem you are having with the Integrated Installer?
Could you post a screenshot of the error related with DFU?
I also suggest you to try with the flashall script:
Charlie
Carlos_M_Intel
Do you have updates on this? Have you been able to use your board?
Charlie
