Intel® Makers
9868 Discussions
Intel Edison pwm using mraa not going low
HC_R
Hi
I'm using the pwm3 interface for starting a vibration motor, so I wrote these functions for it
# define MRAA_PWM3_PIN_NUM 21
void InitVibrationPWM(void) {
pwm3Context = mraa_pwm_init(MRAA_PWM3_PIN_NUM);
mraa_pwm_enable (pwm3Context,0);
mraa_pwm_period_us(pwm3Context, 1000);
mraa_pwm_pulsewidth_us(pwm3Context,500);
void StartVibrationPWM(void) {
mraa_pwm_enable (pwm3Context,1);
void StopVibrationPWM(void) {
mraa_pwm_pulsewidth_us(pwm3Context,1);
But the issue is when I stop and start the PWM several times the PWM output wont get low when I eventually stop the PWM, that line always stays high eventhough I called StopVibrationPWM(). This happens randomly so that I cant figure out the exact issue.
Any thoughts
Community Manager
Hi Hari_CR,
This is indeed a known issue, and hopefully it will be fixed in the future. If you read all the interactions from the GitHub link you provided, you could see that a workaround/fix has already been proposed by alext-mkrs (you can see it here https://github.com/intel-iot-devkit/mraa/pull/515 https://github.com/intel-iot-devkit/mraa/pull/515), so hopefully this one will be implemented soon.
-Pablo
HC_R
Hi recently I found this stating that, this might be a hardware issue. Can somebody from intel verify that
https://github.com/intel-iot-devkit/mraa/issues/91 [API] PWM should disable pin when 0 is written · Issue # 91 · intel-iot-devkit/mraa · GitHub
Community Manager
Hi Hari_CR,
-Pablo
