Intel® Makers
9880 Discussions
Intel Edison static IP working connection to Ubiquity rocket M5 in bridge mode
HLeeu
Dear all,
For my project I am working on the Edison with mini breakout powered by battery (7,4V) on J21 and wirelessly (WiFi) connected to the Ubiquity rocket M5 with a powerful antenna.
AM5G16AirMax Sector 5G-16-120: 5 Ghz 16 dBi 120 degrees 2x2 MIMO
I use it to make a very powerful WiFi network which I can use on stage. The antenna is a sector antenna and thus looks explicitly in a certain direction. It also functions in the 5 GHz band which is not very populated...
In my configuration I use it in bridge mode which means that the rocket does not function as a router but directly funnels the signal through to the computer through ethernet. It is like a computer to computer connection.
This makes connecting to it hard with the Edison. I cannot use the standard setup tool since that works with DHCP and the rocket in bridge mode does not hand out IP addresses. So I have to go for the static option.
I had it connected in the past using this post:
I had been lucky then though. Since I had a new Edison to configure I had to follow the steps again...
I followed the lines of the script:
Juiste antwoord door DiegoV_Intel op 9-dec-2015 8:31
Hello DaveFer,
Try with the steps below:
  • Connect to wireless network using connman. Run the following commands in the Edison's console:
  1. systemctl start connman
  2. systemctl enable connman
  3. connmanctl
  4. enable wifi
  5. scan wifi
systemctl start connman systemctl enable connman connmanctl enable wifi scan wifi
  • Wait for the scan completed message and then run the following command:
  1. services
services
  • A list of the available networks will be displayed with the following format:
  • Then run the following commands:
  1. agent on
  2. connect
agent on connect
  • At this point you will be asked for the passphrase. Enter the network password and then run the following command:
  1. exit
exit
  • Now you should be connected to the network. After a successful connection gather the gateway, netmask and broadcast information with the following commands:
For gateway information:
  1. netstat -nr
netstat -nr
For netmask and broadcast information:
  1. ifconfig wlan0
ifconfig wlan0
>>>>>NOW HERE I HAVE A PROBLEM!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
>>>>>Since the Rocket does not hand out an ip address I get no ip address, no net mask and no gateway. None the less I went on and did also the next step:
  • Now proceed to configure and set the static IP address using the service, gateway and netmask gathered with the following command:
  1. connmanctl config --ipv4 manual
<p style="min-height: 8pt;...
HLeeu
For some reason the second half of my post is only visible for a second. I copied some html code which is probably the reason.
HLeeu
Dear all,
Another try at my post...
/thread/94270 Configuring Edison for a static IP address ...
  3. connmanctl
  4. enable wifi
  5. scan wifi
  1. services
  1. agent on
  2. connect
  1. exit
  1. netstat -nr
  1. ifconfig wlan0
>>>>>although I did not get any information from ifconfig wlan0 I forced the and anyway in the same network as the network that I had chosen for the Rocket - computer ethernet connection. If I subsequently pinged the ip address nothing happened though.
>>>>>I also did the step of creating the /etc/network/interfaces file for which the procedure is in the original post.
>>>>>If I then rebooted the Edison, there was no connection. Repeating the connman procedure would give errors and after the 'services' command service names that had a lot of zero's in them would show up.
>>>>>So I decided to start from scratch. I deleted the /etc/network/interfaces file that I had just created and I also got rid of all the entries in the /etc/wpa_supplicant/wpa_supplicant.conf file, leaving only this in that file:
ctrl_interface=/var/run/wpa_supplicant
ctrl_interface_group=0
config_methods=virtual_push_button virtual_display push_button keypad
update_config=1
fast_reauth=1
device_name=Edison
manufacturer=Intel
model_name=Edison
>>>>>So I restarted, was ready to start the procedure again but then saw in connmanctl when I asked for 'services' that the Edison seemed to be connected to the Rocket!!!
>>>>>A much bigger present was the fact that after rebooting the Ediso...
Community Manager
Hi Hans,
Thanks for your interest in the Intel® Edison™ Platform.
I'm glad to know that you fixed your issue by your own! And thanks for sharing your results in such a detailed manner.
Now, regarding an explanation of the strange behavior of Connman. I personally don't have too much experience with Connman, but maybe your questions could be answered by looking through the Connman documentation https://01.org/connman/documentation https://01.org/connman/documentation .
Please let me know if any questions come up, have a nice day!
-Jose P.
