Intel® Makers
9881 Discussions
Intel Edison upload problem with Arduino IDE 1602 LCD I2C
CLin82
Hi all,
I have a question about the upload issue. I used a Arduino breakout board and Grove base shield. I have connected a 9V external power adapter and two micro USB.
I used an analog pin to read data from a light sensor and a temperature sensor then display it on a 1602 I2C lCD (refresh every second). It works after upload finished with all the power and USB port connected. But when I unplug the micro USB (keep the 9V external power connected), it didn't work anymore. The LCD is stuck and stop refreshing.
The library I used in my sketch are
# include
# include
# include "rgb_lcd.h" // LCD
# include // Grove temperature sensor
Can any one tell me what is wrong?
Thanks a lot !
Diego_V_Intel
Hello channinglin,
According to your description, it seems to be a known issue reported in the latest Yocto image. This means that the issue is neither in the Arduino sketch nor the libraries you use, but in the Yocto image version.
I recommend you to re-flash your Edison with the following Yocto image and check if the issue is resolved: https://downloadcenter.intel.com/downloads/eula/24910/Intel-Edison-Software-Release-2-1?httpDown=htt... Intel Edison Software Release 2.1
Diego.
Diego_V_Intel
Hello channinglin,
Diego.
CLin82
Hi DiegoV,
Yes, you are right! I re-flash my Edison with the Yocto image you link and it works! However, I thought it would start to work and display things as long as I plug the external power. In fact, I have to connect the two micro USB and the external power first, then it starts to work. After that, I can unplug the two micro USB and only keep the power cable.
