Hi! I am using an Intel Edison. When I connect the Edison to my desktop with Ubuntu 16.04 I do not see the interface being assigned an IP address. The Intel Edison does get an IP address i.e. 192.168.2.15 but my Ubuntu system does not get an output. Below is the output for both the devices.
Intel Edison :-
root@Edison:/home/multi_sensor# ifconfig
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
usb0 Link encap:Ethernet HWaddr 02:00:86:c7:e9:83
inet addr:192.168.2.15 Bcast:192.168.2.255 Mask:255.255.255.0
inet6 addr: fe80::86ff:fec7:e983/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:139 errors:0 dropped:0 overruns:0 frame:0
TX packets:91 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:21426 (20.9 KiB) TX bytes:24382 (23.8 KiB)
wlan0 Link encap:Ethernet HWaddr fc:db:b3:7e:61:f5
inet6 addr: fe80::fedb:b3ff:fe7e:61f5/64 Scope:Link
UP BROADCAST MULTICAST MTU:1500 Metric:1
TX packets:43 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:8772 (8.5 KiB)
Ubuntu 16.04 desktop :-
eno1 Link encap:Ethernet HWaddr 00:22:4d:54:b7:b4
inet addr:10.223.96.135 Bcast:10.223.96.255 Mask:255.255.255.0
inet6 addr: fe80::4941:c99:3613:f640/64 Scope:Link
RX packets:68127 errors:0 dropped:0 overruns:0 frame:0
TX packets:43329 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:56869936 (56.8 MB) TX bytes:8963851 (8.9 MB)
Interrupt:20 Memory:fe600000-fe620000
enp0s26u1u1 Link encap:Ethernet HWaddr d6:30:b1:1c:d3:ff
RX packets:91 errors:0 dropped:0 overruns:0 frame:0
TX packets:410 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:19104 (19.1 KB) TX bytes:88798 (88.7 KB)
RX packets:600 errors:0 dropped:0 overruns:0 frame:0
TX packets:600 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:54274 (54.2 KB) TX bytes:54274 (54.2 KB)
Can someone help me fix this?
- Tags:
- Ethernet
Hello parthshah10391,
Thanks for reaching out!
Could you please let us know which steps you have taken so far to create the Ethernet over USB connection?
Are you aware of the following guide?
https://software.intel.com/en-us/connecting-to-intel-edison-board-using-ethernet-over-usb# linux
In case you haven't tried the steps in that guide, could you please do so?
Let us know how it goes.
-Peter.
-Peter.
Hi parthshah10391,
I'm glad to hear that!
If you ever have any doubts, please don't hesitate to come back to the community, we'll be happy to help you.
-Peter.
