Community
cancel
Showing results for
Search instead for
Did you mean:
zpeng2
Intel Edison with UEFI
How to power on Edison with UEFI BIOS?
CommunityAdminintel_admin
Community Manager
Hi VictorZZ,
Thank you for contacting us. The methods to power the Edison module vary depending on the breakout board you're using it with. The power methods for each of the boards are explained in each hardware guide, so I'd recommend you to take a look at the following documents choose the method based on the specifications.
Mini Breakout Board (Section 2.1) http://www.intel.com/content/www/us/en/support/boards-and-kits/000005574.html
Arduino breakout Board (Section 4) http://www.intel.com/content/www/us/en/support/boards-and-kits/000005583.html .
Let us know if there's anything else we can assist you with.
-Sergio A
Community Manager
Hi VictorZZ,
Do you still need assistance with this case? We'll be waiting for your response.
-Sergio A
zpeng2
Thanks, I had got.
It's not support UEFI BIOS.
Power on it by CoreBoot.
Community Manager
Hi VictorZZ,
Thank you for confirming you found the information you were looking for. Don't hesitate to contact us again of help is needed.
-Sergio A
