Community
cancel
Showing results for
Search instead for
Did you mean:
SGupt29
Intel Edison won't run XDK Project on Startup
My Intel Edison Project, a modification of the example:
/*jslint node:true, vars:true, bitwise:true, unparam:true */
/*jshint unused:true */
/*global */
A simple node.js application intended to read data from Analog pins on the Intel based development boards
such as the Intel(R) Galileo and Edison with Arduino breakout board, and display it in a browser running on the client.
This demonstrates use of http.createServer, and fs.
MRAA - Low Level Skeleton Library for Communication on GNU/Linux platforms
Library in C/C++ to interface with Galileo & other Intel platforms, in a structured and sane API with port nanmes/numbering that match boards & with bindings to javascript & python.
Steps for installing MRAA & UPM Library on Intel IoT Platform with IoTDevKit Linux* image
Using a ssh client:
1. echo "src maa-upm http://iotdk.intel.com/repos/1.1/intelgalactic http://iotdk.intel.com/repos/1.1/intelgalactic" > /etc/opkg/intel-iotdk.conf
2. opkg update
3. opkg upgrade
Article: https://software.intel.com/en-us/xdk-sample-creating-a-web-server https://software.intel.com/en-us/xdk-sample-creating-a-web-server
// Set this to the ip address of your board (not 127.0.0.1)
var ipAddress = '192.168.1.80';
var mraa = require('mraa'); //require mraa
console.log('MRAA Version: ' + mraa.getVersion()); //write the mraa version to the console
// Start by loading in some data
var fs = require('fs');
var lightSensorPage = fs.readFileSync('/node_app_slot/lightsensor.html');
// Insert the ip address in the code in the page
lightSensorPage = String(lightSensorPage).replace(/<<ipAddress>>/, ipAddress);
var myDigitalPin6 = new mraa.Gpio(6); //setup digital read on Digital pin # 6 (D6)
myDigitalPin6.dir(mraa.DIR_IN); //set the gpio direction to input
* Given a value, convert it to Lux
* This uses the table given in the documentation for the
* Grove Starter Kit Plus. We have not sought to verify these
* values with our device. That would be worth doing if you
* intend to rely on these values. In that case, it could also
* be worthwhile to improve the interpolation formula
* @param {Number} - the raw reading from the device
var http = require('http');
http.createServer(function (req, res) {
var value;
// This is a very quick and dirty way of detecting a request for the page
// versus a request for light values
if (req.url.indexOf('lightsensor') != -1) {
res.writeHead(200, {'Content-Type': 'text/html'});
res.end(lightSensorPage);
else {
value = myDigitalPin6.read();
res.writeHead(200, {'Content-Type': 'text/json'});
res.end(JSON.stringify(value));
}).listen(1337, ipAddress);
Once uploaded to the board in the Intel XDK, can be run using the run button. If i unplug the board and plug it back in, the project won't run on startup, but after it starts up, i can manually start it by using the run button in the XDK IDE. Any help?
I am using the mini breakout and the Yocto 3.0 image.
Community Manager
Hi Shiven,
If you want to start your script automatically when the Edison boots, I recommend you to create a system service to run the script on startup. You would have to create a script directly in the Edison's console instead of uploading it using the XDK. You could still using the XDK to make sure the script works as expected, and then create the system service to run it on startup. The following document describes the process you should follow to create a system service: /docs/DOC-111103 https://communities.intel.com/docs/DOC-111103
Diego
SGupt29
Are you sure? The LED Blink example works on startup.
Community Manager
Hi Shiven,
I've just tested the Blink example and it didn't start after I rebooted the board. I'm using the Yocto image version 3.0 too, but I'm not able to get any code from the XDK running after a reboot. Besides the Blink example, have you tested any other code to see if it runs on startup?
Diego
SGupt29
Community Manager
Hi Shiven,
I tested your code and I was able to get it running on startup. Then, I tested the following Blink example: https://github.com/intel-iot-devkit/mraa/blob/master/examples/javascript/Blink-IO.js https://github.com/intel-iot-devkit/mraa/blob/master/examples/javascript/Blink-IO.js, but the code didn't run on startup. Then, I tested your code again but this time, I wasn't able to get it running on startup.
Let me run additional tests to see why this behavior is happening.
Diego
SGupt29
This also happens to me sometimes, but I can fix this be clearing the node app slot directory in upload control in the ide.
I do this a couple of times and it works. Not sure what is going on
Community Manager
Hi Shiven,
Just to let you know that we're still looking into this.
Once we have updates, we'll let you know.
Diego
RRobe17
Very odd, I never had any issues with my code running after a reboot.
WaiLun_P_Intel
Hi Shiven,
Has your issue been resolved? Please ensure that you have enabled "Automatically run after upload" in the upload options:
Wai Lun
