Intel® Makers
9881 Discussions
[Intel Flash tool] fastboot error
sshin12
I am trying to flash Brillo images using the Intel flash tool in windows. And error I get seem to be not related to Brillo, but generic flash tool error.
So when I follow this process,
Copy all built files along with json, bin, img files in one folder and then try full flash with flash tool then I get error
01/28/16 04:45:35.789 INFO : [Port 1] Running `"/usr/lib/phoneflashtoollite/fastboot" "-s" "" "flash" "gpt" "/mnt/hgfs/D/brillo/gpt.bin"` command
01/28/16 04:46:35.796 WARNING: [Port 1] Command `/usr/lib/phoneflashtoollite/fastboot "-s" "" "flash" "gpt" "/mnt/hgfs/D/brillo/gpt.bin"` timed out (60 s)
01/28/16 04:46:35.797 INFO : [Port 1] Retrying `"/usr/lib/phoneflashtoollite/fastboot" "-s" "" "flash" "gpt" "/mnt/hgfs/D/brillo/gpt.bin"` command
01/28/16 04:47:35.807 ERROR : [Port 1] Command `/usr/lib/phoneflashtoollite/fastboot "-s" "" "flash" "gpt" "/mnt/hgfs/D/brillo/gpt.bin"` timed out (60 s)
01/28/16 04:47:35.807 ERROR : [Port 1] Flash failed (Command type: Fastboot)
Do we have reboot the edison in fastboot mode manually OR did flashtool did it by itself?
Anyone facing this issue?
please let me know how you guys resolved it.
Any help would be really appreciated
Thanks n Regards
Sangi
Sergio_A_Intel
Hi sangi,
I'd suggest you to take a look https://software.intel.com/en-us/iot/brillo IoT - Brillo | Intel® Developer Zone . For software issues related to Brillo you can go to the support section and post your question on there as well. Hopefully you can get a useful response there, if you do please share your answer with the community.
Sergio
Sergio_A_Intel
Hi sangi,
Sergio
