I am quite new to this board and I have been trying to communicate between two galileos using XBee s2's.
I am using arduino software for this purpose.
Initially I tried shorting the tx/rx(Serial1) of the gen 2 and tried sending text and simultaneously printing when received.But it started printing junk values like forever until I had to close the program itself.
below is the code
int readValue = 0;
void setup() {
// put your setup code here, to run once:
Serial.begin(9600);
Serial1.begin(9600);
void loop() {
// put your main code here, to run repeatedly:
Serial1.write("Hey how are you?");
delay(1000);
if (Serial1.available() > 0) {
int val = Serial1.read();
Serial.println(val);
I have a remote router API configured to the coordinator pan(connected to the gen 2).
Firstly, I had connected tx of module to rx of board, and similarly the rx of module to the tx of board.
Secondly, I had configured the router API to keep sending its ADC values.
Another observation was that , when the coordinator and router are connected to a usb and are observed using the XCTU software, I am perfectly receiving the sample values.
I tried using the XBee-Arduino-Master library, famous one for arduino, for receiving the values but again was unsuccessful.
I used the below code to print the values coming from the serial port.
void setup() {
Serial.begin(9600);
Serial.println("Hello and welcome!!");
void loop() {
if(Serial1.available()){
Serial.println(Serial1.read(),HEX);
delay(500);
Any advice on how to proceed ?
Have you read http://www.intel.com/content/www/us/en/support/boards-and-kits/000005913.html Intel® Galileo and Intel® Edison Board Shield Testing Report for...? Section 2 "XBee* S2 Module w/Arduino* Wireless Proto Shield". It contains a detailed explanation and code that has been tested with the Gen 2.
Review the document and let me know if you find useful information here.
Sergio
Sergio
