Community
cancel
Showing results for
Search instead for
Did you mean:
JSoto6
Intel Galileo GEN2 and HC SR04 ultrasonic sensor with PYTHON and wiringx86
Jump to solution
Hello!
I have to make a security project, using Galileo and python, NO arduino, and I'm using the emutex library wiringx86 to manipulate the I/O de Galileo, so far, I've made the code and it works! but my main problem is taht when I sense 120 cm, Galileo shows me from 115 to 121 cm, it never stay quiet! it changes a lot!.
Another problem , when I sense short distances, for example 5 cm o 10 cm, five lectures are ok but the next one returns -800560, I don't know what's going on!
The last problem I'm facing, when I sense short distances, it returns like 20 lectures, and it stops but it doesn't quit the loop, but it doesn't send data, but when I sense large distances, it's ok ...
Hope some answers! Thank you all!!
Best Regards!
FTinetti
Honored Contributor I
Hi JuanMarcelo,
Maybe some of the following threads would help?
/message/340739# 340739 https://communities.intel.com/message/340739# 340739
/message/238963# 238963 https://communities.intel.com/message/238963# 238963
/message/264878# 264878 https://communities.intel.com/message/264878# 264878
/message/256956# 256956 https://communities.intel.com/message/256956# 256956
Fernando.
FTinetti
Hi JuanMarcelo,
Fernando.
